Question about SanDisk Sansa E280 MP3 Player
My Sansa Kepps Telling Me I Have Bad Tracks
I have had my sansa for about a year now. it has worked fine till 3 days ago. i turned it on to listen to it and it said that just about every song is a bad track. i turn it off the i deleted everything off of it beacuse i thought that there might be a corupt file. deleted everything downloaded a new song put it on it worked. downloaded more the i put those on and it said then all of them are bad tracks. what do i do? it i format the device and if i have to how do i do that?
  • 8,596 Answers
Some DRM-encrypted files have a fixed time limit for how long you can use/play a song. after the time period has lapsed, they will show up as "Error - File Format..." (this is only one possibility)
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Posted on Mar 18, 2008
SOURCE:
After downloading songs on my Sansa View, some of the tracks are bad. I've tried to delete the bad tracks but Sansa View won't let me. Also, when a bad track appears the Sansa View freezes. Sometimes it...
have you consulted customer service on this? It sounds to me like it might be a drm issue, where drm is a form of licensing that stop you playing files without the license.If it is that kind of problem Sansa should recognise it straight away and then you'll know what to do. in the meantime you could try doing a reset as per the instructions that came with the player or go to the website and download the manual.
Sep 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
LOST SPACE!
same thing happened to me it still doesn't work and mine is supposed to hold 500 it only holds 150
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Listening
well i had same problem try this
1.take all songs to computer (and pictures ,movies)
2.make sure your computer dont shows hidden(needed files) files.. if you are using xp or vista do this controll panel/folder options
3. delete all music,pictures,movies on your mp3/mp4 ( dont delete any thing other!! )
4.pull the music back to it
/it worked for me well well hopes it works
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Is my player messed up or is it napster
Need to keep your msuic svc subscription updated, and resync eveyr 30 days or more
Sep 20, 2007 | SanDisk Sansa e250 MP3 Player
I need Help!!!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
Sandisk sansa e250 keeps retarting
you should try formating it. when you plug it into your computer... go to my computer right click on your mp3 player name under " devices with removable storage" click format. make sure nothing is checked. and then press start. wait till its done, and it should work. good luck. i can use some to..
May 11, 2007 | SanDisk Sansa e250 MP3 Player
Sansa frozen
try taking off the back plate and take out the battery then put it back in and turn it on
Feb 08, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
81 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
