Question about Microwave Ovens
Maytag mmv1153aaw ehaust fan turns on
Maytag mmv1153aaw
ehaust fan turns on for no reason. I have unit open, if I can just clip the wire for the exhaust fan that would be fine. Any ideas?
  • Microwave Ovens Master
  • 9,098 Answers
Normally the hood / exhaust fan comes on when you turn it on, or when the temperature at the bottom of the microwave gets high enough to close the hood thermostat.
Sometimes a failure of the hood thermostat or on the control board can cause intermittent or unintended operation of the hood fan.
A thermostat can only trip so many time before it fails permanently.
One way to test it is to unplug one wire from the thermostat, tape it up to prevent it from shorting, and see how it acts for a couple of days.
If it stops failing, the hood thermostat is bad., If it continues to fail, chances are you have a failure on the control board, which we can repair for $39.95 in most cases.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
Maytag Model MMV1153AAW vent won't turn off; we have to unplug it and plug it in to use it so the vent won't run 24/7. When we plug it back in to use it, the vent comes on within 15 seconds and might shut...
Either your thermostat or relay to the blower has faulted. Thermostat is cheap but the relay is on the control board. So either replace the thermostat P#53001373 or replace the microwave as the control board is discontinued according to the information you provided. Good Luck
Jan 02, 2015 | Maytag Microwave Ovens
I have a 1000watts maytag microwave MMV1153AAW the condenserfan was running by itself on and off i disconnected the wire bacause it drove me crazy now the transformer is sparking up on me is the any...
Unfortunately, if you have cut a wire internally then any warranty will be void.
Have you investigated why the transformer is sparking? This sounds like either a serious problem with the transformer or simply a loose connection.
I assume when you cut the wire you have made sure that it is insulated from the chassis?
Mar 21, 2010 | Maytag MMV1153A Microwave Oven
My maytag microwaves fan stays on, i broke the bottom latch and glued it back on, still stays on' help?
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("my maytag microwaves fan stays on, i broke the bottom latch and glued it back on, still stays on'"), as well as the answers to these questions:
Which fan is it, the internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Nov 24, 2009 | Maytag MMV4205 Microwave Oven
I have a maytag microwave model # mmv1153aaw..the light and/or air vent turn on all by themselves..I hear a beep, go into the kitchen and the vent is running or the light is on. Is this a fire hazard??...
I have a MMV1153BAB. My service tech mentioned that if use of the surface units overheat the microwave, the microwave fan will come on automatically.
Nov 11, 2009 | Maytag MMV1153A Microwave Oven
Exhaust fan runs continuously on Maytag microwave. Please help
> MMV5165BAB hood vent fan runs continuously
You probably have either a shorted base thermostat on the base of the chassis of the oven or a shorted fan relay on the control circuit board.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
The base thermostat (which I believe has thinner pink and yellow wires attached, but not thicker black wires) should read normally open. If it shows continuity (virtually zero ohms or shorted) then it is bad.
Otherwise, I would say you have a shorted fan relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 18, 2009 | Maytag MMV5165 Microwave Oven
No power maytag mmv1153aaw
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It may be an open fuse, magnetron TCO or oven cavity TCO.
Accessing the oven cavity for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Maytag owner's manuals and installation instructions here.
Jan 27, 2009 | Maytag MMV4205 Microwave Oven
Maytag mmv1153aaw
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
Aug 06, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
285 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
