Question about Medion md40298 Notebook
SATA DRIVER FOR MEDION MD79700
LOOKING TO INSTALL WINDOWS XP AND NEED SATA DRIVER FOR HDD CONTROLLER, THANKS
    Guru:
  • 377 Answers
Dear raufsbu
try this site
http://www.nliteos.com/download.html
i hope it solve your problem
oke, post me back
thx
cropp
Posted on Mar 16, 2008
  • 655 Answers
Can you tell me which main board you have.? Then i can give you link for your dirver.
Otherwise find your main board manufacturer, go to thier site and search for your model no. and make download.
After getting driver if you still have problem, then tell me Insha Allah i will help you to fix.
Thanks
Iqbal
  • bugsbuny333 Apr 13, 2011
    Just go to Medion site and type SATA in the search big list will pop up
    It worked for me i find what i was looking for
Please, give me a Sata driver for this HDD
The driver you need is for the onboard IDE/SATA controller. Locate the make and model of your motherboard, visit the support site that they have online, download the driver for the IDE/SATA/RAID (if applicable) controller.
Mar 24, 2014 | Fujitsu 40GB MHW2040BS SATA Mobile 40 GB...
HDD error no hard drive found, a new hard drive was installed but the result was the same
If system has a SATA HDD and you are using WIndows XP, you may need to load a SATA controller driver before the HDD controller will be recognized by the Winodws setup. Windows XP will require the driver from a floppy diskette, Vista will load from USB or any other type of drive
Sep 28, 2009 | Dell Computers & Internet
I hav a laptop cq60-104tu. i want to install xp on it but it gives an error message. what should i do???
Go to the bios and change the SATA into ATA before installing window xp. You will find this option under hard disk type.
Sep 25, 2009 | Computers & Internet
Unsure of which driver to download
try to go to philips website technical support download since the brand of your computer is philips. there u can download the correct drivers for your hardware! good luck!
Aug 16, 2009 | Computers & Internet
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
Asus P4S800D-X mobo and sata hdd problem
I believe you need to load in the SiS 180 RAID controller for this MOBO during the Windows Install.
Do this by loading the driver onto a floppy and pressing F6 when told to do so by the windows install.
Mar 20, 2009 | ASUS P4S800D-X Motherboard
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Help me to install WinXP in a Gateway Laptop that came with SATA HDD
you have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Jul 19, 2008 | Computers & Internet
HP DV2700Tx Windows vista to XP Downgrade
you will need to download the SATA controller driver from
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56416-1&lc=en&cc=uk&lang=en&os=228&product=3641490&dlc=en
without that your laptop won't recognize your hard drive there
are 2 ways to solve this:
first one you'll need an external floppy drive save the sata driver on a floppy put your xp disk in and start the install at the very begining xp prompts you press F6 to install sata driver press that and it'll get the driver from the external floppy drive.
second way is to create an xp disk with the sata driver to achieve that you'll need a deployment software i use nlite
http://www.nliteos.com/ if you have any problems add me to your msn messenger atlascomputerrepair@hotmail.co.uk and i'll talk you through it
May 03, 2008 | Panasonic U7500 Notebook
I have an Accer Extensa 5220 laptop which came with vista Home Edition. I wanted to down grade the OS to windows XP Pro. After formating the Hard Drive, I ran windows XP setup disk but keeps on giving the...
The problem of your laptop is the hard disk type. because acer 5220 laptop is using a SATA hardisk that automatic detected or supported by Vista. But in the windows Xp you need to download the sata driver for windows xp and save it to the floppy drive. In the beginning of windows installation press F6 to install another device or scsi the windows setup search your floppy drive for the sata driver and install it automatically. If you have cannot fix it just contact me i'm willing to help you
Apr 15, 2008 | Computers & Internet
Medion md40298 Notebook Logo
693 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
