Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Blue haze taking over screen on zenith e44w46lcd 44 in rear projection hdtv Blue Haze Problem
  • 3 more comments
  • smulhern Mar 16, 2008
    This is a mitsubishi ws-55313 I don't know how zenith got in there. It happened two years ago for three or four days on and off. Started again last night but has now started to clear again.
    Thank You.
    That Was ALL Ready Looked At.
    This Problem is intermitent blue haze comes and goes.
    This has got to be some board or power problem, as it is intermitent.
  • 796 Answers
CONTACT TV REPAIR SHOP THIS TV NEEDS FLUID REPLACED can only be done bt tv TECHS
Posted on Mar 16, 2008
  • isaac johny
    isaac johny Mar 16, 2008
    there is some problem in your power board only...
  • isaac johny
    the capacitors must have blown off....
    due to some voltage surges...
    Guru:
  • 1,894 Answers
Sir its just colour balance problem
  • dewan nafees ahmed Mar 16, 2008
    else this must be like this
    THIS TV NEEDS FLUID REPLACED can only be done by tv TECHS
    All three tubes should be
    adjusted for optimum focus and the white balance should be set properly.
    The contrast level that requires the blue to be defocused is far too high
    for most puposes. Your set will look much better, your tubes will last much
    longer, and burn in problems will be much less likely if the contrast is
    reduced to about half on the scales that most of the manufacturers use for
    the consumer level settings. Get one of the calibration discs (avia or
    video essentials) and set levels according to the instructions. Have your
    dealer, servicer, or ISF tech set your white balance properly, focus all
    three tubes properly, and converge the set. Convergence will be easier and
    the results will definitely show up in the resulting picture.
  • 871 Answers
Your light engine has a problem. so, when did this started happening?
  • 1 more comment
  • earl norman llanera
    earl norman llanera Mar 16, 2008
    mitsubishis have a problem with mold growing in the silicone cooling
    jell of the picture tubes. the tubes have a lense
    that is filled with a jell between it and the tube. easy enough to spot, just remove the front screen, and look directly into the three lenses with a flash light. if you see some stuff growing in the jell, thats your problem. you may be able to have the lenses removed, the jell
    cleaned out, and replaced with new. or perhaps all the tubes have become damaged, and need replacement.
    as for your zenith, the bulb needs replacement.
    dnt forget to rate me :)
Light Blue Haze close to the center of the screen
The Optical Engine needs to be replaced. You would need to contact LG / Zenith to get a Service Facility out to confirm the problem and see if they would be willing to help you with the cost. If they do not help with the cost, it will probably not be worth investing the money into it.
I hope this helps,
Skyassoc
Sep 17, 2009 | Zenith E44W46LCD 44" Rear Projection...
I changed the LCD lamp, but there is still a yellow haze.
The yellow haze is the result of the blue polarizer burnt-in, you will find it sitting in front of the dlp chip.
Mar 20, 2009 | Zenith E44W46LCD 44" Rear Projection...
Yellow haze
Hi...the yellow haze is probably the blue filter is burnt and needs replaced. This is very common in Zeniths. There are 3 color filters in the Zeniths blue (pinkish in color), green (grayish in color) and the red (it is red). The #1 problem in this TV is the blue filter is burnt and it is an easy fix. It could also be the LCD cube is bad. I would try the blue filter replacement first. It will probably do the trick.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Jan 17, 2008 | Televison & Video
Yellow haze in center of screen
Typically caused by a defective light engine. Part is over $1000 last time I checked on it. Could also be caused by a bad "digital board". I've seen this symptom more than once on this set.
Sep 26, 2006 | Zenith E44W46LCD 44" Rear Projection...
Blue spot in picture
ADVERTISEMENT/SOLICITATION FROM AN ATTORNEY REGARDING A LEGAL ACTION AGAINST ZENITH/LG If you are interested in speaking with an attorney and/or joining a class action lawsuit concerning the blue haze problem on Zenith and LG rear projection LCD televisions, please contact Daniel E. Sobelsohn by phone or email: Daniel E. Sobelsohn, Esq. The Sobelsohn Law Firm 1901 Avenue of the Stars 2nd Floor Los Angeles, CA 90067 direct dial telephone (310) 461-1333 facsimile (310)861-5205 dsobelsohn@sobelsohnlaw.com
Sep 01, 2006 | Zenith E44W46LCD 44" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
122 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
