Question about Maytag Neptune MAH5500B Front Load Washer
Washing machine leaking fluid - Maytag Neptune MAH5500B Front Load Washer
  • h3hum Mar 16, 2008
    leaking fluid
    President:
  • Maytag Master
  • 2,651 Answers
Like brownish / yellow fluid??? if so its transmission fluid, ck with manufacture for possible warr, usually 5yrs on the transmission
Posted on Mar 16, 2008
How do you tell if the suspension springs are bad
with washing machines you have suspension springs at the top of the drum and shock absorbers on the bottom, the easiest way to check shocks is to see if they have leaked any fluid and if they offer any resistance, if they are leaking and offer no resistance to compression then they will need replacing
Apr 04, 2014 | Washing Machines
Red fluid leak in maytag washer la712
Sounds like gear case oil. Dark Red? Did you tip the washer over?
Sep 03, 2012 | Maytag Washing Machines
F&P washing machine leaking from the bottom of the tub. I have checked the pump and inlets they are all good. It is an Intuitiuve Eco model about 5 years old. The leak seems to be coming the centre...
The seal has gone, you need to replace the seal and bearings and also the shaft as the seal wears into the shaft.. The leak would have started out as brown in colour, then as the grease is washed out of the bearings, the fluid will run clear, then the bearings will start to make a noise when the machine is doing the spin cycle.
Not an easy job to do, hardest part is fitting the seal properly without tearing the lip on the shaft where it drives the agitator. There is a cover available to do so, but only at autherised repair shops.
Apr 29, 2011 | Washing Machines
My maytag washer was makeing noise and we moveved it out and found a black plastic cap that was in two and fluid leak.
The plastic cap goes underneath the washer on the end of the transmission shaft below the belt pulley.
You may have a transmission oil leak causing the noise.
This machine is worth repairing.
It is a better machine than any brand made today.
Nov 12, 2009 | Maytag Dependable Care LAT9416
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
Oil leaking on kenmore model 110
This is probably transmission fluid leaking out. You can fix it. Depending on the age of the unit and how much you are willing to spend on a unit that age. Call us for parts. 972-859-0929. We ship next day air and nationwide. Hope this helps you.
Aug 28, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes have oil spots on them like something is leaking into tub. possible causes? solutions?
generally oil spots are from leaking transmission fluid, and depending on age ofg machine may or may not be worth repairing
Jan 11, 2009 | Washing Machines
I NEED TO REPLACE SOME OF THE TRANSMITION FLUID THAT LEAKED OUT OF MY ROPER WASHING MACHINE WHEN I LEFT IT ON ITS SIDE? WHAT TYPE CAN I USE
any automobile automatic trans fluid would do fine but i am not sure how you are going to replace it.the fluid you lost when it was turned on it's side came out the vent hole on the top.unless you lost a huge amount of fluid,i would not bother.i have seen 20yr old whirlpool's(roper manufacturer)that have lost 2/3rd's of their fluid due to a bad seal run with no trans troubles at all.if you only lost a pint or less,the mach will be fine.good luck
Sep 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer top load heavy duty 80 fluid leaking
It's rusty Water probably the water pump housing is cracked might be replaceable need to take a look at it or call Kenmore for the part
Apr 13, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
279 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
