Question about Electronics - Others
Memory card problem
I have a san disk, micro SD, 1gb memory card, it was working just fine, but then some days ago, i tried sending something to it, and it says operation fail, and i still have 487mb free space, i'm wondering what the problem is
  • 871 Answers
Is it locked? have you tried using that card on another medium? if it has the same error, try to reformat it. and after reformatting it? if it still has that error, you may need to replace that card.
Posted on Mar 16, 2008
SOURCE:
I keep getting card cannot be used every time i put a memory card in my nikon coolpix s210 what can i do to fix this
If formatting does not work then most likely the memory card id faulty.
Memory cards such as SD and USB memory sticks do not last forever. they do fail eventually after many writes and file file deletes or damaged by not using Safely Remove Hardware on the computer.
Jun 11, 2012 | Nikon Coolpix S210 Digital Camera
Micro card not working
See if its shows up in MY Computer. If it does, try formatting the SD card.
Apr 26, 2010 | SanDisk 1GB microSD Memory Card
I have a 2 g memory card which when full I uploaded to my PC and then deleated all photos from the memory card I tried to use this card again but the camera tells me the memory card is full also it tells...
Exactly the same problem occurred with my San Disk 1GB micro-SD Memory Card. And I solved this problem formatting my micro-SD Memory Card using a software which you can download by clicking here.
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the installed "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
That's all my friend. This solved my problem and I hope this helps you too.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | SanDisk 2GB microSD Memory Card
LG Tritan does not take PNY Micro SD
If you've tried to do a firmware update and it still would not recognize the chipset, then there is not much else you can do.
Aug 20, 2009 | LG RUMOR Cellular Phone
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
Can any 1 give me some tips????...............
i think u r not using a data cable for the file transfer.... u r using thatcardreader right... these card reader dont work with the micro sd cards... use a data cable it costs 140 bucks....
Nov 02, 2008 | Nokia 3110 Cellular Phone
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Unlock 1 GB micro sd memory card of Kingston Made
i forgot my password...pls help me unlocked. i have got nokia 6233with 1gb micro sd. i tried to give password for the sd card. but it doesnt worked. i tried it many times. one day my phone automatically got switched off. when i switched on the phone the sd card was locked and it was asking for the password..i tried many passwords but not able to open it.. what shall i do npw . is there any software or something to open the sd card.....anyone please help me.......Solve This!
I have the same problem
Aug 23, 2008 | Nokia 6151 Cellular Phone
Micro SD Not Reading
I have same problem with A1200 not recognize micro sd card.
some one help ,Please.
Thank - you.
Oct 07, 2007 | Motorola Mobility A1200
Electronics - Others Logo
100 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
