Question about Gateway FPD2275W LCD Monitor
Duel monitor my nvidea card has both of these connections,only the second connection which is on every card you are showing me isnt the same as my monitor connection,do i need something to go on the end of my second monitor connection or do i still need a second card?
    Problem Solver:
  • 12 Answers
Which connector are you currently using? They should be white and blue.(hint: the blue is VGA, the white is DVI). If you're using the VGA connector on both monitors, you will need to purchase an DVI to VGA adapter. Fairly common and can be found online for less than $5 here: http://www.newegg.com/Product/Product.aspx?Item=N82E16814998101
Now, if you're wanting to use two DVI monitors, you'll need to buy a video card that has two DVI connectors already on it, as you cannot convert VGA to DVI.
Posted on Mar 21, 2008
Will my 64mb GF2 support dvi and / or hdmi connection (I want to get a flat panel monitor)
Not directly......but no worries!
All hope is not lost with just the VGA out on your card!
First, every flat panel monitor I have ever seen has a VGA input, so your GeForce2 card will still work!
VGA is still the top analog signal standard for computers. I am writing this with my on-board NVIDEA GeForce, connected to a Viewsonic VA2226w flat panel monitor using VGA and set at a resolution of 1680X1050!
Almost forgot..... just ignore the "TV Out" on your card.... this is old school and will give you nowhere near the quality you will get from VGA.... it was meant as a "crowd pleaser" to allow people to connect to their old school big screen TV sets.
Get the flat panel display... you will find out that it will work just fine with your VGA connection.
Feb 19, 2011 | Nvidia GeForce2 MX400 Graphic Card
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the video...
No it can not be possible you can use multiple cable two way .it can solve your problem.Some mother board or laptop has duel option. In that devic can any body use two moniter.
Nov 24, 2010 | Intel Computers & Internet
Do I need a PCI card for my new LG Flatron monitor to get it to work in multi-monitor mode?
the  multi-monitor is more than one. so The Vga Cards after PCI models has all cards can connect to two monitor same time. needs a spliter cable on vga Output. and ATI Software or Nvidea Software to enable the second Monitor.
Dec 28, 2009 | Computers & Internet
I work with 2x193W LCD Monitors together. One is working fine, the other is now giving me the "No signal" screen. I have checked connections and pins. Everything seems alright. What am I missing?
Open you video cards control panel and check the display settings. Check to see if it is set to duel view or single display. You can also open your display settings for your computer. Under the settings tab choose which monitor is showing no signal and make sure it has a check mark on the box that says extend my windows desktop onto this monitor.
Jun 08, 2009 | Acer X193W LCD Monitor
Nvidia geforce9400gt monitor problem
Usually the problem with windows 7. if you have 2cables connecting from youre monitor to the graphics card, unplug one of them, it worked for another guy
Mar 24, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Duel monitor
If I read your problem correctly, it appears that you are trying to plug a monitor into your nVidia card AND the integrated video at the same time. Unfortunately, you can only use one or the other. However, if you purchase a low-cost dual monitor card (less than $30), you will be in business.
If you know what kind of slot your current video card uses, then here are links to the lowest cost options for each on Newegg.
PCI - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102447
AGP - http://www.newegg.com/Product/Product.aspx?Item=N82E16814136007
PCI-Express - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102536
Mar 16, 2008 | Gateway FPD2275W LCD Monitor
Installing a second dvd drive
hi
you need to use dual monitor display card (http://www.superwarehouse.com/Dual_Monitor_Video_Cards/c3/1884).
thanks
Mar 15, 2008 | Computers & Internet
Installing AGP video card
Don't boot with the monitor connected to the card. You need to let it boot into windows and install the drivers for it first. Once you do that,shutdown and restart with the monitor plugged into it and it should work.
Sep 13, 2007 | Sis 6326, (4 MB) Graphic Card
Gateway FPD2275W LCD Monitor Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
