Question about Sanyo DS31520 31" TV
Fuse inside tv keeps blowing
After i replaced the fuse inside the tv, the fuse blown again in two to three days. what could be the problem or problems causing it to continue blowing the fuse after it is used in a few days.
please help!
  • Debbie Johnston
    Debbie Johnston Mar 20, 2008
    I have the Sanyo
    DS-31450 31" TV and it just started doing the same thing in Febuary. Is this a capacitor a handy home person with a knowledge soldering can do?
    Scholar:
  • 135 Answers
Hi there!
If the fuse rating is correct as indicated on the board, then the PTC is probably busy going faulty. If not sure where it is located, normally on the front where the switch is and where the coil that sits around the tube is connected to the board. Little plastic box with three pins(sometimes two) black or cream in colour. Some circuits use a disc type with 2 legs, however not sure on your set. This is called the degausing circuit and demagnetises the tube every time you switch the TV on. Good luck, JUS004
Posted on Mar 16, 2008
Automatic transmission not shifting gears
Replacing any fuse after it has blown ,your almost
guaranteed it will blow again
At least you know the circuit with the problem
Now you go to factory wiring diagrams, to see what that
fuse controls & do some testing
Have to have wiring diagrams,be able to read them & know
basic electricity & be able to test your vehicle,then you have
to be able to continue on with professional tools, once the fuse
issue is resolved, if the fuse keeps blowing every few days
You could have wiring issues,more likely inside the trans in the oily
environment ,you could have solenoid or module failure or mechanical trans issues
I would say you can't resolve at home,need professional help
Mar 14, 2014 | Ford Expedition Cars & Trucks
ECI Fuse keeps blowing
What ever was blowing the fuse intermittently now has a full blow dead short. Trace it through to the unit and check for connections shorting out or the unit itself shorting out.
Jan 10, 2014 | Cars & Trucks
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
Fuse keeps blowing out on Panasonic CT36HL44J TV
Thanks for this post. It inspired me to replace my fuse in my TV and it is working great now... I took pics of the process in case anybody wants to see what they are in for. http://joedotcom.com/2009/09/01/panasonic-fuse/ Although I did use a 6.3a fuse (just like I removed). I read on another forum that you can replace it with a 7a fuse and get better results. I have had this TV for years and this is the first blown fuse. If it becomes a reoccuring theme, i may up it to the 7a.
Jan 14, 2009 | Panasonic CT-36HL43 36" TV
P0440
The canister vent valve and the oxygen sensors get their power from this fuse(along with some other things) wich means you could have a bad component or a wiring problem anywhere between them and that blown fuse. You can try to unplug each component and try it again. just a suggestion - try the oxygen sensors first as they have a heater circuit inside them wich can short out. The pink and black wire going to the vent valve should be 12 volts with a good fuse in that circuit. Get a circuit breaker from radio shack or napa to go into that blowing fuse so you don't keep having to throw all your fuses out after you blow them. The po440 means you have a small leak in the evap system but you need to repair the blowing fuse first wich could also have something to do with the vent valve- they go bad very often.- good luck
Sep 14, 2008 | 2001 Pontiac Grand Am SE
SAMSUNG STANDARD TV SET
maybe you have a blown fuse,try to have a look first inside,if you have a blown fuse then replace it with the same rating,if it blows again replace your power regulator
Jun 30, 2008 | Samsung TXJ2554 TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Sanyo DS31520 31" TV Logo
198 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
