Question about KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
I have a two year old fridge, that has only been used periodically (second home). After loading groceries last night upon arrival here, the fridge went to a 65 degree temp and will not return to 38 despite my lowering the temp repeatedly. The freezer is functioning fine. Please advise. Thanks. JS
    President:
  • KitchenAid Master
  • 2,651 Answers
Could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Posted on Mar 16, 2008
WHIRLPOOL REFRIGERATOR FRENCH DOOR ENERGYSTAR 5 MO OLD SAYS COOLING SYSYEM OFF ?
STOP! Don't worry about the other responses- it is SO simple to fix. You just press the two right two buttons (lock and measured fill) at the same time and hold for 3 seconds. That's it!!
May 23, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Afi2538aeb will not cool refridgerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Amana AFI2538AEB (256 cu ft) Bottom...
6 year old LG French Door bottom frezer now has ice builup on the floor of the bottom freezer.
heatman101
Jul 17, 2011 | LG Refrigerators
Two year old Fridge with bottom freezer and french door upper. Cold freezer and a warm fridge how can we correct this?
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
Jun 27, 2011 | Amana Refrigerators
Refrigerator/Freezer has no power
get an electrician to check if your fridge plug has got power. you might have a faulty wall plug or a faulty fridge plug.
Sep 06, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Condensation in refrigerator even in the morning
Are the temps in the fridge and freerzer as cold as they should be? The air circulates through the unit and the moisture is taken out in the freezer by the evaporator coils. If they are not cold enough the moisture won't be taken out. The freezer fan has to run to do this and the damper (vent) between the freezer and fridge has to be open. A door not closing good and leaky door gaskets will cause excess moisture.
Aug 19, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator Logo
197 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
