Question about Mitsubishi VS-5043 50" Rear Projection Television
Colers not lined up
I just got the mitsubishi vs-5043 and the colers ore ofe the wont line up and i dont know what it is
  • 58 Answers
The problem with your TV is the convergence IC's are failing. This is an economical but complicated repair. Unless you are a skilled technician, I would not recommend you trying this repair on your own. For your information, the part number for the IC's is STK392-570. Hope this helps.
Posted on Apr 03, 2008
SOURCE:
Manual for mitsubishi vs 5043 cannot program for
If you go into the main menue with the Mitsubishi remote, there should be a set up icon for programing stations. It should give you a selection for cable and or standard tuning. Select cable then press auto program.
Hope this got it done,
Skyassoc
Jun 19, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 5043 no picture
have the tubes checked out you may have a loose connection
Jul 15, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi cs 35203
That sounds like vertical failure. Does the blue line run across the screen from side to side? Try resoldering the vertical output IC and see if that straightens it out. This is sometimes been a problem with that chassis. Let me know how you make out or if you need additional help.
Mar 29, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-5041
if you know someone with a dish network remote they have a cancel button.... i had the same problem and fixed it this way
Mar 17, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi vs-5043
Look for short on Green CRT board.
Aug 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Black horizontal lines on mitsubishi VS-5043
Is the noise in all inputs (line, tumer) ? If it is in the tuner alone, check the coax lug to see if you knocked it loose. This could be the problem. Check you picture with a DVD player on the Video input. Let me know what you find.
Jul 03, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
