Bose 3 2 1 GSX System Logo
Posted on Apr 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD skipping problem, power off then back on will fix for a while but will happen a few minutes later. On DVD problem, switching to FM input then back to DVD input will temporarily fix but will happen again either by itself or when DVD is stopped, paused and restarted etc.
Anonymous
Level 2:
New Friend:
  • Expert 148 Answers
  • Posted on Apr 04, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
148
Questions
0
Helped
27220
Points
347
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
My bose av321 makes humming noises wether it is on or off
The DVD mechanisms is defective,it's gears are not in alignment.The noise you hear is from the motor,it will continue to spin and stop if it is not attached to any gear
We have a Bose 321 GS in our house and it usually works great, but for the past couple of days it has been, well, crappy. Every time we a DVD in it plays for a little while, but then it freezes and stops....
DVD player producse clicking noise when the focus len move up and down. hitting the DVD disk. This usually indicate that the lenses are dirty. Cleaning the top focus len usually resolve the problem.
I burned an mp4 on to a disc but will not play on my 321 gsx sbose ystem Says unsupported format I used the nero smart startsmart program and tried to burn as a data and as a video
I check 321 gsx sbose system that you use to play the DVD and it claims that it supports CD-R, CD-RW, SACD, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, Video CD (NTSC, PAL). So make sure that the DVD that you burn the video onto should be compatible with your DVD player. And you can also refer to this post about burning mp4 with nero to make sure that you burn with right steps.
1helpful
I have a Bose 321, 5 years old. It has started dropping the dialogue track on DVDs but the music track still plays. It is tempremental about the DVDs it plays, often reads bad disk or the DVD freezes. ...
BOSE offered a software upgrade to address the issue of freezing and not playing certain disks. You can get that right from BOSE by calling tech support. I am not sure that that will help with the newest symptom though (the humming).
Audio problems with Bose 321 system
Hi, sounds like the centre front speaker is disconnected. Check the wiring on that, if all is good there then a fault most likely with the amp. To make sure try connecting a different speaker to the centre channel just for test purpose to eliminate a speaker/cable fault. Best of luck
I have sound but no video when I play DVD's
The picture signal cable should be attached to the TV or maybe the channel is set wrong...Try channel 3 - 4 or channel 90 on TV
Bose AV28 DVD player is making a clicking noise
The strip must have fallen or attached to the CD spinner
29helpful
3answers
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
3answers
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
