Question about SanDisk Sansa c200 MP3 Player
Frozen image Once powered up, the main menu screen does not come up. It is full blue with a small orange moon in the upper right corner of the screen. Cannot get to any of the functions.
Take a very close look at the screen, you might find a plastic
protective sheet adhered to it......just peel it off !!
Posted on Mar 22, 2008
  • 21 Answers
I am suspecting that the battery is dead. Have you tried replacing the battery? You can always contact SanDisk for support. If it is still under warranty, then just send it back for a replacement.
Posted on Mar 16, 2008
Tip
Sansa Mp3 player frozen? How to reset and format if needed.
To reset your Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch.3. To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
You will lose all your music - sorry. Also try: 1. From the Main Menu, in the player -> select Settings -> Format.2. Select Yes.
You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the player to the PC in MTP (See next step to change to MTP mode) .
1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that...
Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
on Jan 24, 2010 | Audio Players & Recorders
How do I unfreeze my Apple ipad air ?
It's actually very easy, once you know how to do it. Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom).
Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
May 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Cant get an image.Is it right that the view finderimage is upside down
The image of all astronomical telescopes are upside down (SCTs are upside down and reversed). RACI (right angled, correct image) finders do produce a right-side up image. For daytime use a erect image prism eyepiece.
Follow below instructions (except 7 in your case)
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Feb 28, 2013 | Vivitar Viv-tel-76700 75x/350x Reflector...
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Upper righthand corner, blue full moon, 1 cm in size. (solid blue circle)
The LCD in your phone got damaged and so try to replace the LCD in the authorized service station.
Jul 25, 2009 | Samsung SGH-t819 Cellular Phone
Nokia 6103 LCD screen broken, need to transfer contacts to SIM
Menu
down once
menu
menu
upper left
down 4 times
menu
menu
down once
menu
(now you have to decide - for keep original press menu, for move original down once and menu)
upper left
menu
Dec 11, 2008 | Nokia 6103 Cellular Phone
Power Saver not working
The Logitech wireless keyboard "moon" key set the power saver on but would not return the screen no mater what key I hit. So, I connected a standard wired keyboard and hit the space bar. Once returned I disabled the "moon" key though the Logitech software.
Nov 19, 2008 | Logitech Cordless Desktop MX3200 Laser...
TV screen is frozen
Look for a button on the remote or front of the set that is labeled input (could be tv/video) this switches between video inputs and the tuner.
Oct 25, 2008 | Sanyo DS24205 24" TV
SanDisk Sansa  c200 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
