Honda_Cr-V_2001-2006
Starter - Removal & Installation
2.0L
Engine
Negative battery cable
Starter wiring harness connectors
Starter motor
To install:
Starter motor. Tighten the bolts to 33 ft. lbs. (44 Nm).
Starter wiring harness connectors. Tighten the battery cable nut
to 79 inch lbs. (9 Nm).
2.4L Engine
Knock sensor connector
Starter motor
Fig. Starter mounting
To install:
Install or connect the following:
Starter motor. Tighten the upper bolt to 33 ft. lbs. (44 Nm); the
lower bolt to 47 ft. lbs. (64 Nm).
to 84 inch lbs. (9 Nm).
Hope this help (remember comment and rated this).
SOURCE: 2002 honda crv air filter change
Hi!
Can you specify if you are referring to the engine intake air filter or the cabin air filter?
If you are referencing the cabin air filter, the attached youtube video should help.
I originally created the video for the Odyssey, but found out after looking at my dad's CRV that it is essentially the same procedure as the Odyssey, and have also noticed that the same stands true for most Honda vehicles built between 2005 and 2009.
Happy motoring!
SOURCE: 2002 HONDA CRV COLD ANTIFREEZE LEAK
this happens alot on older vehicles most often times because the coolant hose shrink and expand around a fitting. try and tighten all coolant clamps. this often is all it takes to solve the problem. you should also look to see that all seals around heads of engine show no seepage
SOURCE: How can i have 2002 honda crv owner's manual for free?
Well since this is something you want to keep, why not become a member at this site : http://www.tradebit.com/tagworld.php/honda+crv+workshop+repair+service+manual+download Here not only will you get your free manual plus tips, but u decide if u want to.....sodeep
SOURCE: where is the fuel filter located honda crv 2002
normally for honda it should be located to the firewall close to the battery...
