Question about Royal VF700 Cross-Cut Shredder
Worn gear i have a worn drive gear.trying locate aparts manual.any ideas.
  • lathia Apr 11, 2008
    I have a wear gear that is missing teeth and it has about 60 teeth on it with a metal gear inside how do i get a new one. I called a service center and they couldn't help me.
  • terryk7777 Sep 26, 2008
    Royal VF 800 - first large gear off of motor drive (approx 1 1/2 inch diameter) teeth broken...trying to source.
Call spare parts dept 1-800-222-2310
2 for parts
2 for help with part numbers
about 1.75 ea - gears are plastic/metal each seperate- part numbers VF800 - 04 to 07, 04 and 06 are the plastic gears and 05/07 are the accompanying metal gears shipped priority post 2-4days -- too easy!!
Posted on Feb 25, 2010
Royal VF700: I had a major paper jam that stripped the same gear as explained by terryk7777. Called Royal Spare Parts which is listed under "Contact Us" from their website and were able to send me the piece. It was only ~$1.50 +shipping. Buy an extra piece just in case.
The gear is:
Product code: VF800-04 /VF700
Description: Gear #2 Plastic OSP
I recommend also getting the metal gear that is inserted in the plastic gear (sold separately, I think code would be VF800-05 but would verify). I am doing a second order just for that piece because it is impossible for me to extract it from the old gear. I'm also gonna ask if they can throw in a small amount of gear lube for no extra charge. Good luck!
Posted on Feb 22, 2009
  • college kid Feb 22, 2009
    Oh check this site as well for piece diagrams
    http://www.geocities.com/jayrespler2/ind...
What would cause my transmission to whine, but only in gear, not in neutral or park?
Time for a trans rebuilt
What your hearing is mostly pump noise, from
fine debris in the pump valve bores or worn bores
2001 is way over due to come apart
Worn out from heat & wear & seldom seen a fluid change
Funny shifting is worn & hardened rubber parts,partially
clogged solenoids,dirty valve body,the usual, given the years
& mileage on it
Sep 20, 2014 | 2001 Oldsmobile Bravada
Harley Davidson XLH 1000 Sportster Transmission pops out gear
check over your transmission chances are your shift drum ball is worn or your shift drum selector ball spring is weak if any of these parts are worn you will have to take-apart the transmission to replace these parts also wile you've got it apart good idea to check your bearings too.
Jan 23, 2014 | Harley Davidson XLH 1000 Sportster...
Whining in transmission
If the noise was not there before any work was done
recently,then you may be on to something
I would say the whining is in the trans,front input bearing
One of those things you just have to replace & see what happens
That is a home project,not one you pay someone to do
& have no idea what was done
I do all my own work, so I can learn things & control the process
I have all drive shafts checked for being straight,install or have
installed all new joints & always have them balanced
I have all flywheels & clutch assy balanced,only when it it necessary
to have things apart to start with
Sep 12, 2012 | 1992 Isuzu Rodeo
95 GMC sierra. Check gauges light on. Runs on two gears 2nd and 3rd. RPM and speed dead. Some days it runs ok, can tell when gauges work. Did a transmission oil and filter. Same thing...help
you have a ****** problem with only 2 gears to me that seems like the computer is miss firing if its a auto ****** or the clutch is worn out or it can be that the lever inside the ****** is broken so it wont change gears this can be a lot of possibilities sorry i dont know that much i need to drive the vehicle and take apart the ****** to see whats the problem maybe one of these things will give you an idea of whats wrong with it.
May 27, 2012 | 1995 GMC Sierra
My mercedes atego jumped out of gear at about 50mph i was unable to select any gears but when i let the clutch back up and gear stick in neutral position it appears to still be in fourth gear when...
SHIFT LINKAGE WORN OR DAMAGED.BROKEN OR LOOSE INPUT GEAR BEARING RETAINER, COULD HAVE DAMAGED OR WORN CHECK BALLS FORK ROD BALL GROOVES OR CHECK SPRINGS, WORN MAINSHAFT OR COUNTERSHAFT BEARINGS,WORN SYNCHRONIZERS OR CHIPPED OR WORN GEAR TEETH. MANY THINGS WILL CAUSE MANUAL TRANSMISSION TO JUMP OUT OF GEAR.
Jul 21, 2011 | Mercedes-Benz Sprinter Cars & Trucks
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Hi, I am driving a Fiat Sciento 1000, year 2000 - I am struggling at times getting into gear from 1st to 2nd especially, and sometimes end up hazards on until i've got into gear ok.
If the clutch feels strong and it is only happening on 1 or 2 gears, this is likely going to be caused by worn synchros in the transmission. What these items are, little brass rings, shaped like gears themselves that go on the gear shafts and help to align the gear so the shift fork can easily push the other gear into place. If these are worn or broken, you get gears that do not align and grind when use is needed. The transmission will need to be removed and taken apart to determine how much damage is there. This is not a rebuild, but do let an expert give you his opinion about what NEEDS to be done while it is on the bench. Let me know if you need anything else. Unfortunately, I do not have a shop manual for this particular model.
Sep 08, 2010 | Fiat 124 Cars & Trucks
Hello everyone I have a sharp AL-1631 copier and when it starts there is a loud clacking sound coming from the rear drive side of unit can anyone aide me in a resolve?
There could be a few things wrong, but you most likely have a worn out fuser rachet gear, that drives the fusing unit or you may have a worn or broken fuser gear on the upper fixing roller. You can order the parts on line for about $20.00 + shipping. The only hard part is replacing the gears... The one on the Upper fixinfg roller is not that hard, but the rachet gear is kind of tricky... Alot has to come apart and then back togather. It is not hard, but you have to remember where the parts go back too. If you are not very comfortable with taking this apart, it may be a little to much to handel... It, could be just as simple as tighting the fuser screws??? Good Luck..
Apr 18, 2009 | Sharp AL 1631 Copier
Royal VF700 Cross-Cut Shredder Logo
1,581 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
