Question about RCA 32F531T 32" TV
Part numbers I need to find the part numbers and values for a 32f531T Chassis # ITC008WGG, The parts are CZ03 and RZ11.
Look above for answers /cz is .22mfd/16v cap and rz11 is a 15k -ohm resistor/st.
Posted on Mar 22, 2008
Cz03 is a cap and the size is/ .22mfd16v the rz11 is a resistor and the value is 15k ohms 1/4 watt.
Posted on Mar 21, 2008
Hi.ther the czo3 (cap) value is .22mf/16v ,the rz11 (resistor ) is 15k-ohms . the part# for cap is #26223 and # 256743 if you use rca .if not just ask for a .22mfd/16v cap and a 15k 1/4 watt resistor.hope this helps you/ st.
    Sergeant:
    Champion:
  • 375 Answers
Wiil get back to you.
Posted on Mar 20, 2008
I have sound but no picture on my rca 32f531t
you can have these guide:
Flyback Transformer
the horizontal output transistor is for ITC008
search these site you can find more info for your chassis
that was 2 years ago
Sep 28, 2012 | RCA 32F531T 32" TV
Im working on a RCA ITC222-it has 3 chirp problem with burnt CL031. Unfortunately RL106 is burnt (I need value)and, FL100 is open (I need current rating)and finally, DL032 and DL033 are shorted (I need...
Cl031 is the sfaety retrace capacitor check DL030 an the HOT trans they are most likley blown as well. Usually if anything other than the Hot and DL030 are blown the entire deflection board will need replacement. Its also best to check all three of the CRT necks to be sure none are cracked and broken on the CRT necks . Unfortunately several designs of the deflection components had different parts although the deflection boards will usually interchnage bewteen the ITC222 chassis sets. The ITC222A will not interchange. www.tvrepairworld.com has replacement parts and boards and can also assist with part numbers that you require.
Oct 14, 2011 | RCA HD52W59 HDTV Projection Television
I need to know the datasheet for the horizontal's transistor for a tv RCA 32F531T, because I lost the replacement
Hello
The number of horizontal output transistor is [TL 035]. If this number is not available, you can use exact substitute after reffering it to transistor data book and equivalents. OK.
Jun 03, 2011 | RCA 32F531T 32" TV
Beko 32inch L C D model no 32WLK53OHID I NEED POWER SUPPLY PIN OUTS (wich line to wich part and voltage of each line ) from power supply
Hi.
I have problems locating the chassis number correspondent to this model number. I will need chassis number to locate service manual.
Please double check the model number and check if there is chassis written on service tag.
Here manuals for different Beko chassis.
See also here.
Jun 02, 2010 | Televison & Video
Plzzz help me!!!!!
Your defective has defective parts on horizontal section. You need to bring the tv to expert technician,
Jul 26, 2009 | RCA 32F531T 32" TV
B2200 Chassis prt number
They are two totally different frames. The 2200 is a Mazda sourced vehicle while the 2500 is Ford sourced, based on the Ranger pickup.
Mar 11, 2009 | 1988 Mazda B2200
Color convergence still busted
2.2 ohms/1 watt if you have chassis number AP74.
3.3 ohms/1 watt if yo uhave chassis number AP73.
Nov 08, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Looking for convergence part number
yes they are the same Convergence ICs number STK392-110 you need to replace both ICs. You can get replacement ICs at the following link and they provide free instalation instructions with pics so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 12, 2008 | Hitachi 43UWX10B 43" Rear Projection...
CRT
the cost will far exceed replacement value if the crt is faulty.
Apr 08, 2008 | RCA F38310 38" TV
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
RCA 32F531T 32" TV Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
