Question about Technics SL-1210 Turntable
Technics 1210 feedback problem hollow noise ??
Both my Technics 1210 mk3 have a feedback problem, when a record is on the platter, if you knock the deck or tap it, you get a hollow/echo type noise through the speakers. Have check the earth wires which are ok........Please help its driving me nuts !! Cheers Tufty
  • sideyross Jun 09, 2008
    I have exactly the same problem with my decks but it is only noticeable at higher volumes, is not my cartridge and have just replaced rca and earth wire and the chances of 2 tone arms being faulty is pretty slim surely. even if it is any of the above problems seems strange that does it on both decks. Have u found a solution yet mate?
  • 515 Answers
More than likely it's your RCA cables, or it could be a tonearm or cartridge issue. First try and swap out the cartridges on your turntable, and see if the problem persist. If it does, then you can narrow it down tot the tonearm and RCA cables. Since the RCA cables are easier and cheaper to replace, I would suggest doing this first - You can try to do this yourself, however soldering experience is required. You can purchase the parts HERE - and install yourself, or try to find a reputable service center area to replace the cables.
A word of advice, try not to use the original RCA cables that are installed with the turntables, as they aren't of the greatest quality. Try and put a better brand, or use the MOGAMI cables, available HERE.
If the problem persists, then the issue with your tonearm, and replacing the tonearm involves a lot more in-depth work, and I would only suggest having it done by a profession. You can buy the part HERE, and bring it with you to the service center, to minimize your cost.
There is nothing else that would cause this kind of problem except one of the 3 (or combination). So, by a process of elimination, you'll solve the problem.
Have fun!
- DJ PRO AUDIO
www.DJPROLAB.com
Posted on Mar 21, 2008
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
Internal fuse on Technics 1210 Keeps Blowing. Hi there, I have been asked by a friend to repair his decks, I have little electronic knowledge but am having a crack at it any way :) Problem is the Fuse F1...
this was happening last mine with mine aswell i just replaced a fuse then it started to work??
One fuse had colouring on it which i did not know what it meant sop i didnt touch that.
So have you changed both?
Oct 20, 2011 | Technics SL-1210 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
Removing platter
I removed the rubber pad from platter.There is two round holes in platter lift platter by grasping these
holes. wolf545
Dec 14, 2008 | Technics SL-1210 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
High-pitched, repetitive squeaking noise from under platter on 1210MK2
Make sure there is nothing on the magnet part of the platter. Also, sometimes, the screws that hold down the plastic protective cover underneath the platter might not be seated all the way. Lastly, look at the bottom of the magnet, and make sure that it is in tact, and nothing is bent, broken, or cracked.
Other than that, try switching out the platters from your other turntable, and see if the problem persists. You need to rule out what it is not, before you can proceed with finding out what is the problem. So if the noise moves to the other turntable, you know the issue is with the platter. If the noise remains on the same turntable, then you can rule out the platter being the culprit, and can isolate the issue to the turntable. I've never heard of this, and I've fixed well over 3000 Technics 1200MK2/MK3/MK5 turntables in the past 10 years. I am also considered THE 1200s MASTER. So, I am not sure what could be causing this noise, other than some foreign matter. If your in the NY metro area, bring it on by, and I'll take a look at it, or give us a call, and I'll try and refer someone locally for you:
http://www.tweakrepair.com
- J
Jan 14, 2008 | Technics SL-1210 Turntable
1210,s
bad thrust bearing for the platter. use a penetrating oil on the spindle and let stand. then try rotating it after a while.
Sep 11, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
378 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
