Cant install new wireless printer - wizard keeps asking for wep or wpa key
  • 667 Answers
WEP/WPA keys are methods of encryption to protect your wireless network against intruders and hackers. If the install will not let you proceed without one or there is no means of doing this ( by checking a box proceed without key or something like that), you will need create one in your router. I assume that your pc is wired because if it was wireless your wireless card would also need the key before the router would communicate with your pc. Refer to your routers manual on how to create a key and after you do write it down. WPA is more secure. If your pc is wireless you'll also have to enter the key for your wireless card. If so I would recommend doing the router, then your NIC card and then your printer. If not, just create the key in your router (you'll probably have to reboot the router) and then do the printer. If you need the manual for your router or further help feel free to add a comment and I'll help you out.
Posted on Mar 16, 2008
I click on WLAN, then set up wizard. It serched SSID and found the house ID which I click. then it comes up with options: open system, shared key and WPA/WPA2-PSK NO CLUE WHAT ALL THESE MEANS.
Theencryption key secures your data from unauthorized access. Your wireless router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 25, 2011 | Brother MFC 6490CW InkJet Printer
I have an acer computer with and hp photosmart printer connected to a belkin router what is the wpa passphrase to link them
on the front panel of the printer press the tool button and look for wireless settings and press ok. under wireless settings look for wireless setup wizard. it will ask for you wep/wpa. it's the same as your wpa when connecting to a wireless router or wifi.
Mar 23, 2011 | HP Photosmart Premium C309A All-In-One...
Hpj4680 will not print after adding wep pw
Cant you use WPA2, wep is very weak and should never be used if you have the option to use WPA.
If you have used WPA2 security ( you choose the password )
and the printer is asking for a wep key ( the router generates a long key , you dont choose it).
That will be the reason you can't connect, if the printer cant be changed to WPA, you only have the option to log on to the router and change security to WEP, which i would not recommend
Jul 22, 2010 | HP J4680 Office Jet All-In-One Printer
Just installing for wireless but does not pick up network ,wireless light is on. Thanks
Try this :
Press the setup button on the printer;
Goto network setup
Run the wireless setup wizard
It will ask for the WEP or WPA key (Wireless security key)
If you don't have it contact the router company other can check from the EWS page ; put the default gateway(ip address ) in the address bar fo IE and check for the wireless settings; Even if you dont get it check the Below given Link for The network diagnostic utility ; Download it on your desktop and run it ; it will give the WEP/WPA key
Network Diagnostic Utility:
ftp://ftp.hp.com/pub/printers/ndu/
Click on HPHNDU..
Save it to your desktop
Check the WEP/WPA key
Put it in the printer
Select done it will get connected to the network
for further help can check the link given below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01491627&cc=us&lc=en&dlc=en&product=3560280
Oct 25, 2009 | HP Photosmart C6380 All-In-One InkJet...
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Hp c7200 can't connect to wireless network
Try this :
Goto network setup
Put it in the printer select Done
It will get connected to the network;
Check the Link: (for wireless installation)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01084503&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 15, 2009 | HP Office Equipment & Supplies
Wireless problem setup/ What is WEP?
It is the security key used for your wireless router.
When you set up any device to connect to the wireless router you will need it.You should be able to go on you computer,open internet explorer,and type 192.168.1.1 to get to your router page to see all the info needed.
Jan 09, 2009 | HP Photosmart C7280 Printer
New epson Printer with WIFI asking for the PIN
You mean the wireless network key?
To get your wireless network key, do the following steps:
1. Open Internet Explorer, on the address bar type 192.168.1.1
2. There's no username and type admin on the password. If admin didn't work, use your own password.
3. When you have the Setup Page open, click on Wireless Tab, then click on the sub-tab Wireless Security.
4. There you can see the Security Mode. If the mode is set to WEP, the WEP Key 1 is your wireless key. If the mode is set to the WPA-Personal, the Passphrase or the WPA Shared Key is your wireless key/PIN.
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
Wep key for dynex router?
put new router dynex good signal no internet on laptop
Sep 27, 2008 | Dynex DX-E401 Router
I dont remember password
You will need to log into the Router to recieve either the WEP/WPA/WPA-PSK keys from the routers HTTP:// interface Mind tho MACS dont work very well with WEP they do alot better with WPA format
Sep 01, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
