Question about Pentax Optio M30 Digital Camera
Pentax Optio M30
Camera turns on for 3sec makes a grinding sound shuts off its done help!!
  • Anonymous Jul 14, 2008
    same problem here...
  • LegionLabs Feb 11, 2009
    Same problem here. Looking closely into the lens assembly, I see a brass ring slightly out of alignment when I turn it on. The noise is probably caused by gears grinding as they try to move, but might end up slipping. I think this problem can be caused by the lens assembly being hit, contaminated with grit, or opened in a constrained space (like what happens if the camera condescends to open inside a bag filled with junk).
    Unfortunately, it will be hard to fix unless there is an easy way to disassemble the lens assembly. Fortunately, I have an industrial lab at my disposal...
    If I repair it, I'll publish a guide and link it here.
Make sure your battery is charged and if so, take it back to the place you bought it from.
Posted on Mar 31, 2008
SOURCE:
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
How much a GB memorycard/chip can I install on my Pentax Optio M30 digital camera? Bob
You may use any SD card up to 2GB or any SDHC card up to 32GB in size.
Nov 23, 2010 | Pentax Optio M30 Digital Camera
Repair a pentax optio m30 Problem what size
Radio shack sells a mini screwdriver set that is quite extensive. You might find what you're looking for there. Take the camera with you.
May 24, 2010 | Pentax Optio M30 Digital Camera
Optio m30 7.1 mega pixel camera drivers
por favor me ajudem... preciso do drive da PENTAX M30... pois não estou conseguindo baixar as imagens da camera para o computador....
May 18, 2008 | Pentax Optio M30 Digital Camera
Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Feb 25, 2008 | Pentax Optio M30 Digital Camera
My pentax optio M30 turns off after it's on...
Pentax Tech Support will have the remedy- this is where to answer lays- there is no user remedy.
Jul 10, 2007 | Pentax Optio M30 Digital Camera
Pentax Optio M30 Digital Camera Logo
218 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
