Question about Maytag Atlantis MAV6000 Top Load Washer
Spin cycle The final spin cycle does not happen, the machine jyst whines.
  • 1 more comment
  • Vjdty Mar 17, 2008
    The solution you gave is not the problem. The machine will go into the spin mode. The final spin mode is the problem. The humming is come from the controkl panel which leads me to believe it is a switching or sequenting problem.
  • spencer458 Jun 24, 2008
    why would it spin on the first and not the last?
  • spencer458 Jul 02, 2008
    how do you solve this problem?
Would switching out the main dial solve this problem?
Posted on Jun 24, 2008
  • spencer458 Jun 25, 2008
    I still did not get an answer on the spin cycle
Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
When in spin cycle machine makes a very loud whining noise
Most common cause for your whining noise is because the seals have failed/worn and allowed water into the bearings..Rusty ball bearings are not smooth...Hence the noise.....Probably needs bearing/seal and probably shaft replacement....Big job..Get quotes....Good luck...Nomess
May 20, 2010 | Washing Machines
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Final spin cycle does not work
The motor controller is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Kenmore 44042 - No spin cycle
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Oct 17, 2007 | Kenmore 44042 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
