Question about Sony KP-46S25 TV
Sony tv with no image
When i turn the tv on there's no image and the red light blinks twice each time, but no sound or image or any sign of anything.
Please help me with this problem, my tv is a sony kv-25 with more than 10 years of age.
Posted on Aug 15, 2008
6ya staff
SOURCE:
Red LED Light Blinks 7 Times Tv Wont Turn On PLEASE HELP!
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You must have through knowledge in electronics to proceed. This is a very skilled wor. You must have all measuring instruments, and ability to follow its schematic diagram.
Jun 12, 2012 | Sony KV-36XBR400 36" TV
I need a code and instruction to program my remote control with a magnavox tv
  • The Magnavox codes are 32114 and 11434. Should those codes not work then follow these steps to do a code search that will find the code inside the remote.
  1. Turn on your TV.
  2. Press and hold down the SET UP key until the red light blinks twice.
  3. Press Programme - three times. The red light will blink twice.
  4. Alternate between Programme- and Power until your TV turns off.
  5. You may have to press these keys many times, so please be patient.
  6. When your TV turns off, press the SET UP key to store the code. The red light will blink twice. Your TOTAL CONTROL is ready to run your TV.
Regards, Tony
May 18, 2011 | One For All URC4110 Remote Control
Sony rear projection tv kp-51ws500 no picture. Standby light blinking red 5 times. TV has sound but no picture. Before the picture went out TV was turning green then red and had curved lines going...
Blinking 5 times is a sign of at least one of the three video tubes overcurrenting, which will eventually shut off the image. It happened with me but with my red tube over-illuminating. The solution is to reduce the drive intensity on the offending tube. Remove the front speaker grill. Behind it you will find a panal with 6 pots, these are drive (brightness) and focus for each of the 3 colors. My fix was to turn down the red intensity to zero and (after a restart) bring it up slightly till the image was acceptable, colorwise. I did have to adjust all 3 intensities to get a decient color balance along with the focus's on all three tubes (the drive intensity adjustments will knock the focus out as you go). I used the auto-adjust patterns to focus on, and you may want to use a stationary image, such as a paused DVD scene or a video game, to focus on. I still haven't found a way to clear the error code, but I learned to ignore it. The result isn't perfect, but it's very acceptable and it'll do for awhile (and it didn't cost anything!). Good Luck.
Dec 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
I'm trying to program my ''Comcast'' cable box remote control to operate my byd:sign model d:5032M plasma TV. Comcast does not have a standard 4 digit TV code to use. How can I get the code as there is no...
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
Sep 19, 2009 | byD sign d:5032 50 in. HD-Ready Plasma...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Need codes for a AKARI 14" color TV IC-1494RAK
1. Turn TV on
2. Press TV key on remote.
3, Press and Hold magic button until red light blinks twice, it will blink once and then twice.
4. enter 991 red light will blink twice
5. Hit the power button
6. Aim the remote at the TV and press the channel plus button until the TV turns off.
7. Hit the magic button as soon as the TV turns off to store the code.
Hope this works for you!
Jan 03, 2009 | One For All URC 7740 Remote Control
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Televison & Video Logo
243 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
