Caution light I have a Lasko Heather Model 5620, the caution light came on and the unit is not working,what can I do to fix this ?
  • eboe Mar 16, 2008
    This started today 3-16-08
  • eboe Mar 16, 2008
    Yes I've checked those things, what caused the light to come on
  • 871 Answers
When did this started happening?
Posted on Mar 16, 2008
  • 4 more comments
  • earl norman llanera
    earl norman llanera Mar 16, 2008
    check for any parts that is burnt and check if there is faulty wirings for the light to be on .
    check again for the buttons being stuck.
    the heater detects that something is not operating under its safety limits. is there any other that you checked that is not normal?
    have you tried cleaning the heater?
    kindly check if the thermostat feature is properly set and check also what comfort settings are you using.
    if by chance none of this things will work, please check with therecostomer service team with a toll free number. 800-233-0268
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
Cant get the heat to go past 71
Check your thermostat. Maybe it's cutting off ahead of the set temperature. May need recalibration or replacement.
Nov 12, 2012 | Lasko 5620 Electric Baseboard Heater
Orange light came on
The orange light is just an indicator light to show you that the heater is working...there is nothing wrong and nothing to worry about...
heatman101
Jan 04, 2011 | Lasko 5620 Electric Baseboard Heater
Fan heather not work
If you have the model number of the unit ( a series of Letters with a few numbers in it). You can go to www.desatech.com and find the manual for the unit under "Wall Heaters." In the manuals there are usually troubleshooting guides. Hope this helps!
Mar 15, 2010 | Desa International Blower Glow Warm Wall...
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Need manuall for model 5620 electric baseboard heater
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jan 04, 2010 | Lasko Under Desk Space-Saving Area Heater...
Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Mar 04, 2009 | Lasko 5610 Baseboard Heater
Yellow caution light
I also have the model 5620. with the yellow caution light on. After taking the unit completely apart I found 2 thermal fuses on the bottom of the unit(appox. size of a nickel). They are located under 'U" shaped brackets which are below the medal heating element. The thermal fuses do not reset. you could test them with a drip or two of souder or wire on the top - if you ran the heater this way it would be a safety problem as the fuse would be overridden. I am throwning mine away.
Mar 16, 2008 | Heating & Cooling
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
Lasko 5610 red caution light, no power
the caution light is telling you something is wrong. most wired baseboard heaters have a hi limit cutout that may be bad.  it is connected into the heater circuit as a safety device.  you could jump out this element to test this theory.  if the element is shorted, certainly it would blow a fuse or circuit breaker.  if the element is open it won't heat at all.  you need to take it apart and use a test meter to troubleshoot it.
Jan 02, 2007 | Lasko 5610 Baseboard Heater
Heating & Cooling Logo
347 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
