AnandTech
Oct 2, 2007 - 7 posts - 6 authors
wait... does it hesitate to crank or does it hesitate to fire while being cranked? ... If itcranks OK but hesitates to fire, but is fine after it is going and then ... to want to keep the money that you've earned, but not greed to want to ...
Car has left me stranded, where key is in the on position but nothing registers ... While turning the key ignition will not crank over at times will take from 5 to 10 .... it off for a short errand and go right back to start is when I notice more hesitation.
Mar 29, 2006 - 19 posts - 13 authors
If it still hesitates I'd say it was a carburetor issue (accelerator pump, power valve..). If it is only acting up when accelerating (while driving) that would tell me it ... 1980 CJ5Renegade with 304 v8 .... The idle mixture screws were nearly 3 turns out, I think i have them somewhere around 2.5 turns right now.
Dec 8, 2001 - 20 posts - 9 authors
Reving the engine in gear with the clutch in a bit would load the ... alot longer to warm up and tends to hesitate when pulling away from a ... Jeep rater score from the factory:26, today:238 ..... 92 XJ 155/80r13s and 17"s of lift.Missing: cj5
? 7:13
https://www.youtube.com/watch?v=0m4IiVzwjzE
Nov 17, 2013 - Uploaded by Luke Nodzo
Luke will explain why your car may be hesitating or sputtering on... +ameer aklil My 2012 2.5l Frontier does the same thing when it is in 3rd and ...
if your engine light is on you can stop at most any auto parts and they will plug into it free and let u know exactly the problem is most hesitations start with simple solutions if u get them soon there r many things which will cause hesitation dirty air filter number 1 cause alto if i was u i would take the guess work out swing into a autozone oreillys napa any 1 of those will plug into it get the code and tell u what is wrong and clear it for u too
This is likely a problem with the Mass Airflow sensor, it is a sensor that reads the amount of air going into the engine, when it fails it causes severs hesitation and power loss. Contact a local parts store or your GM dealer for a rebuilt one, the part is about $150.00. It is locate in the air intake hose to the engine.
It never hurts to change fluids but, hesitation is a product of fuel and ignition, happening at the correct time and in sufficient quantity. Not sure what "hesitates to work" on your car as you were not specific, but any hesitating is generally a mechanical not a lubrication problem.
