Question about Mitsubishi VS-60705 60" Rear Projection Television
It takes about 5-10 minutes to warm up, then the picture is fine. While warming up the picture wavy and jittery untill it warms up. Is this a picture tube issue?
    Problem Solver:
  • 6 Answers
You have bad capacitors in the power supply or around the 5v & 9v regulator circuits. If you have a meter just measure the outputs of the regulators. If you don't know what a voltage regulator is or does you should call a qualified repair shop. Estimate repair cost $250
Posted on Apr 04, 2010
SOURCE:
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Start up problem
Bill;
Cause 1
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB.
2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Replace all these if they look bad or not. If you can't do it yourself call a service Company and get an estimate, it should cost about $450 if they know what they are doing.
Thanks using FixYa, Big Irish.
Nov 21, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Dark fuzzy picture when tv is first turned on
I am having a similar issue. Did you ever figure out the problem??
Feb 29, 2008 | Televison & Video
Toshiba 50H12 Rear Projection TV wavy screen
There is a Hyper Module mounted right behind the video inputs board. in most cases you can replace the 10uf surface mounts carefully not to tear the foil. and the set will return to normal. or replace the H/M board. this board is soldered 4 tabs on bottom of main board and then pulls out. good luck list of caps cz52(may not have this cap).. cx261 cx270 cx230 cx178 c514 cx221 cx250 cx241 cx541 cx670
Dec 11, 2007 | Televison & Video
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
Jittery picture
the jittering will get worse with on time this tv needs a hyper module and some are still available for replacement id get a new hyper module or have it rebuilt needs caps in the module forget about doing this repair yourself just like the guy on csi miami "they never listen"
Dec 06, 2006 | Toshiba 42H82 42" Rear Projection...
Mitsubishi VS-60705 60" Rear Projection Television Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
