Question about Dishwashers
Hotpoint Dishwasher: HLD404M15SA. I installed the never used dishwasher and the Display Lights don't work. The unit operterates just fine. I tried the reset and powering off a few times, still not even a blink. It didn't come from a dealer, so I don't think the warranty would be an option.
SOURCE:
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
icuppu
  • 3 Answers
SOURCE: kenmore undercounter dishwasher quiet guard
Presuming that your circuit breaker is not tripped and you have power to the dishwasher, it appears that your thermo fuse is blown. You can replace it for around $20. It comes in a kit form or you can replace the thermo fuse for around $1. The part number is NTE 8096 Thermo Fuse 98 degrees Celsius and solder it in yourself. It is located on the circuit board that contains all the relays and the main computer chip. It clips on and off.
Posted on Sep 30, 2008
  • 32 Answers
SOURCE: door lock assembly Hotpoint dishwasher
Hello.
First switch off the power.
Get the cabinet door off, start by removing the side screws that hold the door (please have someone to help you, holding the door, because this doors are heavy.)
After you removed the door, remove the screws holding the fascia (about 2 on each side + 2 holding the door lock).
Remove the fascia and you wil get acess to the door lock, disconnect the wiring from the micro switch, connect the new par and reverse the process.
Cheers
Posted on Feb 19, 2009
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Dishwasher will not empty after cycle and motor makes humming noise hotpoint dishwasher bf1260
The motor is frozen. Remove the bottom kick plate and with unit in off position take a screw driver or use your hands to turn the motor. You will feel the motor when it lets go. Close door and turn on dishwasher and you should be fine. Very common with the GE made dish washers.
Apr 27, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
