My hotpoint oven flashes F2 and it is not even heating up to temp. could it be the thermostat?helpMy hotpoint oven flashes F2 and it is not even heating up to temp. could it be the thermostat?help
You can't post conmments that contain an email address.
F2 is a faulty oven temp sensor. need to replace the sensor. located in the oven cavity 2 screws hoding in protrudes 3-5 inches out thin metal cylinder
Which manufacturer built your oven? The F2 error usually means that the oven temperature sensor is claiming the oven is too hot (or got too hot in the past). This usually requires replacing the temperature sensor. Sometimes, the control unit (clock) needs to be replaced.
I hope this helps. Please add a comment with the make and model of your oven for additional support.
Hello, Thank You for using FixYa. I will be helping you today. F2 means temp exceeds 590 with door unlocked or interference with sensor.Most likely a bad oven sensor..I would replace oven sensor.
Thank You and please rate my answer if it was helpful..
First shut off breaker for 5minutes and see if it resets if not,
F2 indicates a high temp was reached. Remove the temp sensor it is located inside the oven near the top back. 2 screws hold it in.Carefully pull it out there will be 2 wires attached. Check with an ohmeter should have a reading of about 1100 ohms +- 10% if not within that range replace the oven temp sensor. If it checks out good you will need to replace the ERC electronic range control /clock. Both are easy to replace. If you need diagrams or illustrations of your specific model enter your model # at www.appliancehelponline.com. All parts come with installation instructions.
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
