this question is in the wrong category. This category is for computer parts. Please resubmit your question to the cars section.
Try banging the top of the speedo binancle. The 12 or 14 pin behind the speedo is a 'dry' joint and once I cleaned all the pins and sprayed in electrical spray into that fitting ...bingo no more problems.
SOURCE: i have just bought a vauxhall combo van 2004 and
A common fault with the 1700 engines is the airflow meter which is on the air intake, needs plugging into the an ECU diagnostics to check, shouldn't cost much to repair if it is that.
SOURCE: wireing diagam for vauxhall combo diesel van
rac engineer repaired fault for door locks traced fault to fuse board but since then no
reverse lights
