Question about SanDisk Sansa e250 MP3 Player
Refresh Database Hi, i have e250 sansa mp3 player i get continuously refresh database on my player and it never goes off.. i tried your solution of http://www.fixya.com/support/t197433-refresh_database_sansadisk_e270 also my system did not detect though i have added the hardware to it.. it used to work previously fine and the system used to detect and show a drive when i connected it....... i want to format and install new how do i doit..... please suggest... it just hangs at refresh database screen and i cannot do any thing...... neither format nor modify any thing ........ Please also respond to my email [email protected] Regards Sunil
  • Anonymous Oct 06, 2008
    the problem i`m have is that my screen show refresh database and it will not do anything.
  • 8,596 Answers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Apr 08, 2008
2 Suggested Answers
SOURCE:
mixmaster
  • 626 Answers
SOURCE: refresh database SansaDisk e270
Sorry, no habla espanol. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Sep 10, 2007
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Refresh database
Did you try reseting it?
May 25, 2008 | SanDisk Sansa e250 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
How do you refresh database?
This just means that the player is refreshing the songs on the list, it does not mean that you have to do anything.
Feb 02, 2007 | SanDisk Sansa e250 MP3 Player
Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
