Question about Refrigerators
Amana double door freezer side is not working
I have amana double door 1998 built,freezer side is cooling just like the refrigerator side not cooling enough and my ice maker is not working as well.Can somebody help.
  • 1 more comment
  • mustafa123 Mar 16, 2008
    Dear aborcass,
    Thanks for your reply on the freezer side in the bottom doesnt look like there is any frost i am going to open the back panel like you suggested to check for frost.Yes looks like the compressor is kicking on and off and i also cleaned the bottom grill it had dirt built up.I will get back to you soon as i open the back panel.Thanks for your help.
    Dear aborcass,
    Hello after removing the back panel( lower left) i found frost on upper right side of the evaporator what can i do now.Thanks
  • Ron Coons
    Ron Coons May 11, 2010
    can you open the freezer section and see frost building through the lower panel?? if so sounds like a derfost issue. if hteres no frost try removing the panel is there any frost behind there?? does refrig appear to be running at all?? ice maker stopping is normal for a no cooling issue.let me know what you find
    President:
  • Refrigerators Master
  • 2,651 Answers
You can visit the local applaince dealer. frost on onle the top few coils is an indcation of a low charge, restriction of freon, or inneffceint compressor, after 10 years wouldnt image that would be a worth while repair, way expensive here where i am lookna t 500 or so.
Posted on Mar 16, 2008
Refrigerator on my side by side Amana not cooling
check to see if you have a the fan running in the freezer, if not replace fan. if fan is running do you frost on the back wall of freezer, if so defrost by opening door for 3 to 4 hrs. turn back on and if frost returns in 3 to 4 days call for service
Jan 07, 2012 | Amana Refrigerators
Where do I locate the defrost heater 12049801 in an amana ARSE66MB side by side refrigerator?
Good day,
The main heater is a double loop calrod unit mounted to the bottom of the cooling coil located behind the rear panel in the freezer panel.
You can access it by removing the rear panel and if necessary melting any ice or frost built up.
It should be noted it fails rarly, so you should check it with an ohm meter before replacing it.
Here's a picture.
Aug 11, 2010 | Amana ARSE66MB Side by Side Refrigerator
I have an Amana side by side model ARS2664BW. The unit is about 8 years old. The water dispenser on the freezer door quit working and the cooling units inside the freezer and frig are not working proper....
I did a search on Amana.com's knowledge base and didn't find anything useful regarding your two top cooling units not working.
At amana.com, I tried to download the manual, but the service was unavailable until 8/9/2010 after 8:00AM due to system upgrades.
http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=L1&Request_ReadUrl=Y
The above is a service locator for your refrigerator. Since their site doesn't seem to have a solution for this, I would call in the pros if you want to have it fixed more quickly than trying to do it yourself.
Aug 07, 2010 | Amana ARS2464B Side by Side Refrigerator
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Amana Double Door refrigerator not freezing in the freezer side.
sounds like a leak ,as long as the compressor fan is running it is a leak. it can be fixed by a technician only due to the tools needed for the repair. these tools cost well over 1000usd and may not be worth purchasing for a single repair.
Phil
Jun 10, 2009 | Refrigerators
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
