No sound in sm2232bw monitor
I just bought new hp pc with samsung 20"sm 2232bw monitor and there is no sound in monitor
  • Anonymous Apr 29, 2008
    I have just moved house and put together my pc but there is no sound from the monitor. Have checked the connection lead and is connected correctly. Any ideas??
  • 85 Answers
CURSE YOU SAMSUNG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok, I'm done now. Some monitors require a separate power supply for their speakers. I don't know if yours would have one, so you'll have to check. Also, are you sure that you have it connected properly? It you do, are you sure that the monitor has built-in speakers? Once you have checked these things, get back to me.
Posted on Mar 16, 2008
Hi I BOUGHT NEW Samsung SyncMaster P2070 20" LCD Flat Screen Monitor , AND I HAVE HP COMPAQ AND THE MONITOR NOT COMMUNICATE WITH PC
http://support.dell.com/support/edocs/video/p56135/en/connect.htmhttp://support.dell.com/support/edocs/video/p56135/en/connect.htm
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=51555&prodTypeId=329290&objectID=c01525281
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
I have Syncmaster 2232bw. When I first switch it on it flashes for about 1 minute before it stopsa flashing. After that it runs fine until I switch off and it cools. Is this the backlight dying?
This happened with my 2232bw also. The problem was that the 5 820uF capacitors that had burnt out so I replaced them with 5 1000uF capacitors and it's now working like a dream.
Hope This Helps
Slick2160
Oct 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen flickers in 1680x1050 - samsung 2232BW plus
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
Dec 02, 2008 | Computers & Internet
Any suggestions ?
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Oct 29, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung 2232bw monitor
this shows the internal circut problem, need to consult a technician
Oct 28, 2008 | Samsung 226BW Monitor
Hello, I bought a monitor for my laptop,model 2232BW, and I cannot get it to function properly. My wallpaper comes up on the monitor and also my mouse but all my desktop items remain on my laptop...
You have the graphics driver set to Extended Desktop.
If you move the cursor to the right, can you see it on the new monitor?
If so you can drag any application window over to the new monitor.
If you don't like this then right-click on the desktop wallpaper and choose Properties, then find an Advanced tab and an Extended Desktop checkbox and uncheck it.
Aug 03, 2008 | Computers & Internet
2232bw samsung DVI in problem
There is nothing broken, but you must become aware of the different standards in DVI connectors.
1)DVI-D which you have, does not have the 4 analog control pins around the alpha bar meaning it only works on digital devices.
2)DVI-A only has the 4 control pins and no bar, as well as a total of only 9-10 pins altogether. This is designed for analog only, and rarely see it anymore.
3)DVI-I stands for Interlaced, meaning it can work both ways, but will not fit in monitors that are set up for DVI-D because the analog pin sockets do not exist.
You can get more detailed by counting the pins in the rectangular area, if you use all 24 pins you have what is called a Dual-Link cable, so it can support resolutions over 1920x1280 if you have about 9 pins missing it is single-link and is limited resolution.
Jun 08, 2008 | Samsung 226BW Monitor
Try a DVI-D (Digital) Only cable, without the analog (right section). I´m basically talking about a DVI-D to DVI-D cable.
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Computers & Internet Logo
97 people viewed this question
Alun Cox
David Payne
David Payne
