Question about HP Photosmart 7450 InkJet Printer
Please help.... Printer won't take in photo paper, will take regular paper but not the photo paper that I have always used.
  • 4Angyls Mar 19, 2008
    I have had to feed the paper in one at a time for about a year now. While that was annoying at least it was still feeding in. Now it's not. I looked and the wheels inside are still turning. (I have no idea what the technical term is but they look like wheels to me).
    Any ideas?
    Genius:
  • 3,587 Answers
Try it with ONLY photo paper, and nothing under it..
Posted on Mar 16, 2008
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
I have a MAC OS 10.4.11 and an HP Photosmart 3210 all in one. I use Iphoto and have been trying to print a 4 x 6 photo from Iphoto directly to printer. No matter what I try the photo tray does not engage...
I haven't been able to make it work from photo tray either but I do put photo paper in main tray and change settings in Iphoto accordingly and print pics that way.
Oct 02, 2009 | HP Photosmart 3210 Printer
My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
Won't print on regular paper
My quess would be that printhead is becoming clogged, photos don't use as much ink as plain paper printouts that is why they look faded! You need to call Kodak tech support!
Jan 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I need your help please.
Make sure you are using the paper that come under the specifications of the printer (102 x 153 mm (4 x 6 inches) for a Photo Paper). Though you are using the correct paper and you are getting the same message, then just set the paper type as "Plain" and try to print from the photo paper. It works in most of the cases
gud luck
Oct 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
Photo Paper Jams
Based on your question, my first thought is that you changed the type of photo paper you used starting "this week" (when you first posted your question). If you did, the photo paper size/thickness may not be compatible with your printer.
Otherwise, there may be a problem with the paper sensor. Click on the following link and review the troubleshooting steps, particularly Step 2, to see if that helps:
Paper Jam Troubleshooting
Post back your results. If you are still having the problem, post any additional information you think might help solve the problem. Thanks and good luck.
Sep 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Won't take in my photo paper!
hi dear
I had to reread your first post the mention of what to do with all the photo paper. I see you mean that you don't use matte photo paper you use matte heavy weight paper. I guess I mean that as a question! That is the only thing that works for me with no smearing problems. I haven't found one that is thick enough for a good feel. I used an avery matte paper that has a coating for photo but it just feels very light. Doesn't smear and looks sharp but very light weight. What brand do you use ?
post in me back
ok,thanks
cropp
Mar 16, 2008 | HP Photosmart 7450 InkJet Printer
Photo Printer
sina, Does the photo print good using photo paper? How regular of a paper? Do all other colors have ink? What program are you printing the photo from? Have you tried printing from a different program? Some programs send varying information to printers. If all of the above has been tried...uninstall the printer and download the newest drivers from EPSON and re-install the printer. Good luck Tim
Feb 03, 2007 | Epson Stylus Photo 925 InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
