Question about Mitsubishi WS-55613 55" Rear Projection HDTV
55 in mits tv 1080
Turns on ok but after a min it turns off again tried turning on and off time gets shorter tried rest powering down and cleaning . cant seeit to be a fuse issue.thanks
    Sergeant:
  • 395 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Posted on Mar 16, 2008
SOURCE:
Why without warning car would not fire 4 or 5 times, then started ok 4 or 5 times, now won't start again
You will need to figure out if you are lacking spark to the plugs or fuel to the injectors to know which system to test.
Jul 29, 2014 | 1989 Buick LeSabre
Why does power window go down but needs 20 min to rest before going up?
Windows have a down and up sensor. If the down one is not sensing and turning the motor off it will overheat and need time to cool down before moving up again. Remove door panel and check window down sensor. It is either bad or not adjusted properly.
May 07, 2014 | 1999 Lincoln Town Car
Morning or when engine cools down I have to run it for about 15min then it stop dead. wait for 5-10 mins, turn it on and runs again for 2-5 mins than stop again. wait for few more mins and on again, It...
dear sir
this can be problem cause of o2 sensor(lamda sensor) . in cold condition if we start the car some quantity of water can also came out through silencer and can stay at point of 02 sensor it is paced at silencer, ECU(Engine Control Unit) receive data from 02 sensor for Engine Firing . so replace it and let me know. thanks.
Sep 13, 2010 | 1997 Jeep Grand Cherokee
My tv will work for like 5 min then it shuts off
Sound like you have a overheating problem. Your capacitors might have reached their end of life thus making them overheat quickly. Try to check if there is a fan inside your TV. If there is a fan, try to clean it see if that helps.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | RCA TruFlat 27F520T 27" TV
I have i canon mp210 i got the black and colour ink cartridge refilled, but when i put them back in the black and colour light still stay on. i have held down the stop/start button for more then 5 seconds...
Things to try, unplug printer for a min of 10 mins.
clean the chip on front of cartridge with nail varnish remover very lightly though.
Reinstall the cartridge holding down the button for a min of 5 seconds.
If that dont work maybe one of the cartridges have failed it does happen from time to time.
I have my own remanufacturing business so know the market & technology fairly well.
Nov 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Samsung SP50L6HD Tv turns it's self off. Time
sir it may happen if the auto off option is enabled and the timer is enabled........... check for this options if they r and enabled then disable that........... or give your tv to the service shop and check for any problems
Jul 20, 2009 | Samsung Televison & Video
Tv powers off and on after operating for about 1 hour
Same happened to me with my old panasonic set. It was a dry-joint. You can try re-soldering the circuit.
Good Luck.
P.S. - Check the Power Suply area closely.
Feb 20, 2009 | Hitachi 60VX915 Rear Projection Television
Picture becomes unstable after turning it on (lack of color,
The problem is with overheating!. after a few years the fans accumulate dust and "stuff" and don't work as well. Get a can of compressed air and blow out all the ports and fans. I take the cover off and with everything cool, I blow out all the internal fans also. The 3 big fans on the back are easy to remove and clean and get spinning again. Usually this fixes the issue for several months but eventually, professional cleaning may be needed at DWIN.
Dec 23, 2008 | Dwin TransVision 3 Plus Multimedia...
HP Pavilion power up
You could have overheating problem
remove all plates from underneath that allows access to internals and blow out using a can of compressed air (from Radio Shack shop or similar) and ensure fan vent is clean and clear. then try it with all plates off if OK replace plates and try again. If still shuts down laptop requires stripping completely to clean
Oct 15, 2008 | HP (5185-6477) Motherboard
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
