Question about SanDisk Sansa e250 MP3 Player
Help its freezen on load up and will go
  • Anonymous Mar 19, 2008
    My problem is that when I transfer my music to go on my Sansa e250 it's starts transferring it for about 4 seconds then the whole Rhapsody program freezes (locks) up. Prior to this happening, tracks were showing that there were transferring, but when I'd look on Sansa, nothing was there! Currently, it just keeps freezing up.
Begin using Windows Media Player. make sure you have your USB mode set correctly
Posted on Mar 19, 2008
SOURCE:
Model ARB2259CS,Everything is freezen in fridge
first check to make sure that your fence in your fridge and freezer are being blocked by packages there are vents that help circulation from one area to the other. it doesn't help when your pants are not locked then it is most likely your thermostat has gone bad and needs to be replaced
Jan 04, 2015 | Amana Refrigerators
My red light keep coming on all the time on my freezen
Check the condenser is clean, and you can hear the compressor humming. Also check the door shuts properly
May 10, 2014 | Engel Freezers
Flavel fridge freezer
you may have it to close to the wall and ur out of freon
Dec 06, 2013 | Ovens
Password
go to mobile shop they will crack the password for you
Nov 12, 2013 | Samsung GT E1080 Cellular phone - GSM -...
How do i unfreeze my nextbook
You wait until it dies. Then charge it.
Apr 23, 2012 | Nextbook Tablets & eReaders
A/C compressor kicks off when low side pressure hits 35-40 psi. Why is this?
COMPRESSOR WILL KICKS OFF IF PRESSURE TOO HIGH.OR PREVENT AC SYSTEM FROM FREEZEN UP.
Jun 29, 2010 | 1993 Jeep Grand Cherokee
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
REFRIGERATOR NOT FREEZEN OR COOLING
Check the little motor on bottom of the ice box near the compressor. clean those coils. if the compressor is hot then the relay might be bad. If nothing is running below then she is stuck in defrost mode.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Whirlpool GS5SHAXN Side by Side...
SanDisk Sansa e250 MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
