Question about Olevia LT23HVX 23 in. LCD Television
My service port looks like an 8-pin mini din mouse port
Did they change the service port? I have a 30". I don't know where I can find a cable with a USB-A and an 8-pin. Any help?
    New Friend:
  • 54 Answers
If you are just trying to 'jump start' the tv to turn it on, get a usb cable, like the one you use to charge your cell phone. Touch the metal part of the service port, the 8-pin mini din witht he end of your charger cable that is plugged into the wall, until you see a flash on the screen, then turn the tv on like you normally would. It should turn on. If it doesn't jump it again.
Posted on Mar 04, 2010
SOURCE:
Where can I get the mini din connector for the 5.1 input. I need to make up a lead
The only two mini DIN connectors on a SuperMicro H8QG6-F are the keyboard and the mouse, and they are interchangeable.
Cut the cord off of a dead mouse or keyboard and use it.
Cheaper than buying the connector at an electronics supply store.
Regards, Chris
May 26, 2015 | SuperMicro A H8QG6-F AMD Motherboard Quad...
What is the wiring for a ADB to USB Adapter for the 64210 I need to make one
I'm not entirely sure that ADB is eight-way DIN. It sounds more like RS232.
Dec 04, 2013 | ACCO Brands Kensington Turbo Mouse (64210)...
Jd520 error read c71
DIN unlock is related to a digital clock being missing so the unit is looking for a digital input of some kind. Since your laptop is putting out analog change the MD input to analog and of course use the correct inputs. A 1/8" or 3.5mm audio cable may fit into an optical port but it will never work in that way.
Nov 14, 2012 | Sony MDS-JE520 Mini Disc Player
No sound
To answer this one, we'll need a lot more information. The following
1. Verify your cable. There's no way to post a picture so we'll try this in text. Looking at the 5-pin DIN (called P1) with the pins to the top, number them 1 through 5 from left to right (regardless of how they may be numbered on a connector as it is unmarked on the cable). Looking at the 8-pin mini DIN (called P2) with the key at the top, number the top row 1 through 3 (left to right in all cases), the middle row 4 through 6 (pin 6 will be the one separated by a gap from the other two), number the bottom row 7 and 8.
Now, make sure that continuity exists. This is how my cable was wired as follows: P1-1 to P2-7, P1-2 to P2-8, P1-3 and P1-4 to P2-6, P1-5 to P2-1. If you do not show that each wire is good, then you either have a damaged cable or audio is not being output by the Bose control unit or your system uses a different cable wiring, which means that you will need to verify that your cable connects each 5 pin DIN to some on the 8 pin mini DIN
2. Make sure that a headphone is not inserted in the headphone jack on the side. If it is, then sound in not connected to the rear ports. It may sound silly, but someone may have connected headphones and nobody realized that they're still connected.
3. Do you have an oscilloscope? If so, then you'll need to insert wires into the 8-pin mini DIN connector for the zone you're using. Using the pinouts from step one for the cable connector will create a mirror at the Bose jack as follows, left to right, top to bottom 3, 2, 1 - 6, (gap) 5, 4 - 8, 7.
Audio comes out at pins 7 and 8. So connect your scope at those points and ground the probe by clipping it to one the RCA shields. Turn the unit on and make sure that you have a source producing signal, such as a disc or a radio station and see if you see signal. The output at these pins appears rather low, so you set your scope sensitive enough.
My Bose produced audio, but also clicking at an increasing frequency and amplitude as the unit heated up, that results in a lot of noise. I verified the wiring and output with this method.
Feb 18, 2011 | Bose Lifestyle 20 System
Zoom 9030 works well after all these years there is a memory battery that needs to be changed every 5 years or so. The only problem is when I plug in the 8050 foot controller it won't change any patches...
It is LIKELY that one or more pins and or wires in the remote cable are broken.
These MINI DIN connectors are "tender" and are easily broken and wires flex at the back of the connector and are broken.
FIRST check that all pins are present at BOTH ENDS of the cable.
NEXT use an ohmmeter to check continuity of each and every pin end-to-end. I suspect you will find one or more broken.
Be aware that repairing this cable requires patience and steady hand as the pins are so close together it is easy to have solder bridges, etc. Sometimes just opening the connectors are a problem to access the pins. Sometimes the cables are MOLDED and those are UNREPAIRABLE other than cutting off the bad conector and replacing it. You can usually buy replacement connectors at DIGIKEY.com and or Mouser.com. You have to CAREFULLY select the apporpriate pin configuration from the catalog page. One needs a small soldering iron and magnifying glass to work on the cable.
USUALLY the wires go from pin to pin. Also a shield on the cable has to be dressed and connected usually. You may find the shell of the connector tied to a pin or just the sheild of the cable.
Jan 08, 2010 | Zoom Music
Is the system cable wired as a serial connector
u can get one from cablesondemand.com 8 pin mini din male/male
Oct 19, 2009 | JVC TH-M303 System
Epson Photo PC Mini Cable
you can use the same serial cable for the model photopc 500 600 700 it is 8pin NOT 5pin
you can see the specs here for your camera
http://files.support.epson.com/pdf/phpc__/phpc__sl.pdf
and it it at ebay just type the right name
EPSON PHOTOPC SERIAL CABLE 8 PIN
Oct 08, 2009 | Epson PhotoPC 650 Digital Camera
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Televison & Video Logo
120 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
