Question about Water Heaters
Pro-Com heater problems
I live in Boise City, OK elevation 4,167 feet. I have problems with my pilot staying lit. I have read where others have had the same problem. I have blown out the lines to no improvement. The pilot is noisy and simply goes out for no apparent reason often. Could altitude be the problem??? If so, would a different orrifice help???
Duane Johnson
RDJPics@hotmail.com
  • chipinnc May 11, 2010
    I believe you posted this in the wrong area. You are posted in the computer server area.
  • lynn smith Oct 12, 2011
    Did you find a fix to the problem as I have the same issues. ljsmith49@hotmail.com
  • 2,740 Answers
I moved you to water heater
if this is HVAC (heating)
say so
the heaters on all these have fail safe.
in the case of water heater, it has thermal-coupler
that feels the heat of the pilot flame, if not hot now, it cuts the gas.
Natural gas or whatever gas there.
on my huge HVAC the heater (flame starter) is huge.
it glows red now , and has 2 safeties, (huge volumes for gas)
the first is the glow bar, has optical sensor that sees IR light and if the blow bar lighter is dead, gas will not flow
then if that glows and the gas fails to ignite, a simular sensor
detects this and will not open gas solenoid.
so bad initor
bad pilot
bad controls
why not call the service man and not blow self up.
Posted on Aug 07, 2017
    Prodigy:
    An expert who has answered 500 questions.
  • 510 Answers
You need to post in the correct category, you cannot just post anywhere and hope for the best, posting in the correct category would most likely get you the answer to your problem, as this is computers & internet i myself have absolutely no idea, if i did i would help, have you tried the manufacturer of the heater surely they can help, i have included a link for their website which may help, good luck.
Innovation without borders
Posted on Aug 06, 2017
IB4G2008
  • 3587 Answers
SOURCE: HP Deskjet 970cxi
go to control panel, and look at the ports to make certain they are enabled..if not, remove them, then do a scan for hardware changes, and then try it again. I recommend you remove anything plugged into those ports while doing this.
check your computers warranty here 4 FREE
Posted on Mar 24, 2008
SOURCE: hp wireless assistant 3.00 C2
Hi my hp wireless assistant 'HPQWA.msi has stopped working, can anyone help please?
Regards
Mike
Posted on Sep 05, 2008
SOURCE: Print size
go to programs,ok than what ??????? there are no programs on my comp. under computer,,
Posted on Oct 14, 2008
likha
  • 790 Answers
SOURCE: Compaq Presario V2000 card slot not reading SD
Hi
try to connect your card reader to other PC if they can read!? if not you need a driver for your Card reader to read all card.
Thanks!
Posted on Jun 07, 2009
SOURCE: Hotmail I want to get rid of hotmail.com & return to msn. com as my email address. How do I do that????? Thank you
They used to have an account with MSN.com. Now it's all integrated into one so MSN.com uses your hotmail or live.com or .ca for your email. So if you're trying to get rid of your account you can't because it will still ask you for your hotmail or live ID.
Posted on Oct 27, 2011
GCV 40 100 Burner and pilot shuts off when heating up
Get more fresh air to the unit.
Clean the air intake/ flame trap/ flame arrestor located on bottom of tank.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment with type of gas control valve, for possible troubleshoot.
Copy following link to read service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 17, 2012 | A.O. Smith GCV-40 Promax Residential Water...
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Pilot light not staying lit
Before calling service technician, open following links for Bosch Tankless resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BOTechSupport/Troubleshoot/tabid/602/Default.aspx
The problem may be as simple as needing to catching up on pilot maintenance.
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-24_Removing_cleaning_and_replacing_standing_pilot.pdf
Other problems can include low gas pressure, faulty sensor, faulty gas valve, tripped ECO/ safety circuit, safety circuit connections need cleaning.
Add a comment and say what you did to fix problem to help others with same problem.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Bosch AQ125BO LP AquaStar 4.3 GPM Outdoor...
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
Apr 08, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Whirlpool will not stay lit, having to relit about every month
Before calling service technician, open following links for help diagnosing common causes
http://waterheatertimer.org/pdf/Corrosive-atmospheres.pdf
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 28, 2011 | Whirlpool Water Heaters
Pilot will not stay lit..its random..stays on for days or just a few hrs
Open following link for Bosch tankless troubleshooting resources, including Bosch contact number and link for finding service technician, etc.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Feb 23, 2011 | Bosch & Tankless LP Hot Water Heater
Pilot won't stay lit
Possible thermocouple is defective. The thermocouple is heated by the pilot itself, the theory behind this safety design is so the main burner cannot come on, if the thermocouple won't stay hot, it reduces the chance for a huge gas buildup in the burner compartment and possible explosion.
I have also seen cases a pilot would not stay lit if the flue for the heater is blocked by a spider web, bird nest or other obstruction.
Check and make sure the flue/vent is absolutely clean and clear, if it is, then the thermocouple may be defective. If you have an electric pigtail on the thermocouple, the problem may be the electronics or circuit board.
Here is a link to a photo of a thermocouple
https://www.centraltrailer.com/cart/images/2631-3481.jpg
Dec 22, 2009 | Whirlpool Water Heaters
PILOT LIGHT WILL NOT STAY LIT THE TANK HAS BEEN ON FOR THREE YEars with no problems
most of the promblems with gas heaters not staying lit are the theromer cuppling by the pilot is either dirty, built up. or it gone bad and cant be read by the flame.
Aug 30, 2009 | Water Heaters
Water Heaters Logo
481 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
