Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Converting from lp gas to natural gas
Does this model number need a conversion kit or just adjusting orvices
  • Anonymous Jun 06, 2008
    What do I need to do to convert this range (GE Spectra XL44) from natural gas to propane? If I need parts, where do I get them?
    President:
  • GE Master
  • 2,651 Answers
Just the orifices will do, the bake and broilerahve an adjustable hood thatwill need to be tightened down as well as an adjustment made to the regulator(needs brass nut flipped from nat. to lp.)
Posted on Mar 16, 2008
Gaffers and sattler stove
SOURCE:Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Natural gas to LP conversion of Gaffers Sattler stove
Feb 12, 2018 | Kitchen Ranges
How to change from natural gas to LP
Brian, You usually have to purchase a conversion kit for your make and model #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stove conversion natural gas to Lp
Range Conversion
How to Convert Natural Gas To Propane DoItYourself com
Converting LPG and Natural Gas Appliances
May 12, 2016 | Kitchen Ranges
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
What is the product # for the conversion kit from nat gas to lp? who carries this item? Does the conversion kit come with a regulator?
Some Thermador ranges are not field convertable from natural gas to LP. The PRG364EDG falls in this category. If you have one that is not convertiable; you will need a different range.
The PG364GEBS is not a listed unit at Thermador; I've found it for sale at AJ Madison. Since that vendor doesn't list the conversion kit (and they sell ones for other Thermador ranges), I do not believe this is a field convertible unit.
Thermador has manuals and installation guides for many of their appliances here: http://www.thermador.com/trade/specifications-guides . Most Thermador ranges come with the installation guide, as well as the owner's guide, if you still have your documentation. Otherwise, try the Thermador site for the documentation (check if the company uses a different part number internally). If the conversion kit is available, the part number will be provided in the section on the Gas Requirements and Hookup. If it isn't, the installation guide will clearly state that fact.
Other models are convertible. The PRD304GHU uses the conversion unit: PALPKITHC. You will need to confirm your model since the number of orifices will depend on the number of burners and the low simmer feature. (The PRD304GHU is also a 4 burner with 2 of them extra-low simmer burners model.)
For units that are convertible, you can usually order the part through the same stores that sell the appliance. Alternatively, have your gas service installer order the parts. The installation guide for the conversion kit will be included in the kit. For most ranges that are field convertable, the regulator converts from natural gas to LP by rotating a cap in the regulator by 180 degrees. (Take out the part, turn it over so that LP shows and reinstall.)
I hope this helps and I wiish that I had better news for you.
Mar 03, 2011 | Thermador PG364GEBS Stainless Steel Gas...
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
Want to convert heater from natual gas to lpg are jets available for this conversion.heater model no reh210ec thankyou
Dont know if you can get orvices for that heater but almost all gas appliances can be converted for nat to lp and lp to nat,they made a spud kit which is a blank orvice that you drill out your nat gas orvice to I think a 20 drill side and install the spud in and redrill to size usally a nat-gas orvice is around 8 to 10 sizes larger then a lp.The big thing is the gas valve and if it has a built in regulator or not,some valves can be conferted to open up the regulator pressure by the spring or a block off kit and others are fixed and cant be changed,have to replace valve.most nat-gas are at 3" to7" and lp is at 10".Hope this helps you
Jul 05, 2010 | Heating & Cooling
Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
May 31, 2009 | Weber S-420 (NG)
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
251 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
