Question about Canon PIXMA MP600 all-In-One InkJet Printer
Ink carriage will not stop at centre to allow change of ink cartridges
I was very successfully using the Canon PIXMA MP600 on a Microsoft based computer for about a year but recently changed it to work with an imac computer. It was configured (attached to work) with drivers obtained via the internet as I had misplaced the CD for the Macintosh computer setup that came with the MP600. The psc (MP600) WAS WORKING SATISFACTORILY but as the ink cartridges started to show that they needed replacing I ran into the difficulty I am now reporting. I have tried all possibilities that I can think of but still cannot get the CARRIAGE carrying the ink cartridges to stop at the central position to allow any replacement.
By the way, I have since found the CD disk. What am I to do?
  • Gordon Laurie Mar 18, 2008
    Thanks Cropp
    However after numerous tries I was not successful.
    Perhaps I should disconnect the MP600 from the iMac (Tiger issue) where I had used drivers that I had down-loaded from the internet and reinstall using the CD that came with the MP600 (which I have found). Perhaps the trouble exists in this interconnection. The ink cartridge changing had previously been done successfully when the MP600 had been connected to my MicroSoft computer. The problem I am experiencing has only appeared with this next need for cartridge changes on the computer that I bought for my wife. I am mystified!
    Thanks again for you effort -- do you have any other suggestions. (as you probably can tell, I am a rather non-geek person).
    Star7
    Guru:
  • 377 Answers
Hi star
Try this
After the printer decides the cartridge is empty it will start giving you warnings. Eventually it will give you a message to press the Stop/Reset switch for approx. 5 seconds to disable ink level monitoring on the empty cartridge. Ink level monitoring will be re enabled if a new OEM Canon cartridge is installed. There is no way to reset the chip on the cartridge but you can replace for new ink
oke
cropp
Posted on Mar 16, 2008
Canon MP600 printer not printing correctly
The cleaning sponges are on a spingy pad, which can get stuck because of the old ink get a bit gunky. This can cause error 5101.
Try this...
Open the bonnet, use a torch, gently tug the ink carriage to the left of the rails.
Clear any paper jammed in the right of the ink carriage.
Lightly press the cleaning sponges down, (I used a long pen)
Restart the printer.
Jan 12, 2012 | Canon PIXMA MP600 all-In-One InkJet...
MP610 won't print "Inner cover open" appeared after daughter attempted to change ink cartridge. Ink carriage doesn't come over into position for me to inspect the cartridges.
Turn off and unplug from the wall for 60 seconds. Make a visual inspection to see if anything is blocking carriage movement. Plug back into wall and switch printer back on. Give it a few moments to reset itself. If successful, you should be able to change cartridges normally. If not, you may have caused gears to jump out of timing. Try this process at least 3 times before you give up.
Apr 26, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Carriage assembly canon mp600 printer ink chip
It may well be cheaper to replace the printer than pay for the repair.
Dec 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Ink replacement
open the front part of the cabinet and there u get to see the black cartridge gently pull it out and then replace it with new one
Sep 04, 2009 | Canon Pixma MP600 Printer
MP600 2 black ink cartridges...
You can't control which ink is used, the smaller one is used mostly in photos and graphics where more shading control is necessary. The large one is the only one used when you are printing plain text documents that call for black type.
Aug 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
Apr 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer problem
Pretend you need to replace the ink again. Open the MP600 so the carriage moves to the center (just like your going to replace the ink). Than power off the printer. Remove the cartridges & look very closely at the copper contacts. (Sometime when you remove the protective tape some of the sticky tape leaves a residue. If you can not see anything than get some house hold alcohol & a couple cotton swabs. Dampen the cotton & wipe the copper contacts on the ink cartridge (Not the bottom) & the copper contacts inside the carriage. Let everything dry. Alcohol does not leave a residue. Return the ink cartridges (good tight fit). Close the lid & power on the printer. Print a test page.
Left click once on the start button, slide up to & click on Printers and Faxes. The Printer and Faxes window will open. Right click once on your MP600 & left click on properties. Click Print a test page. If the colors did not come out correctly than run an alignment through your printer software & try again.
Everything I mention above is based on the idea that your printer was running just fine but you ran out of ink.
Please correct me if this is not the case.
Good Luck!
If I can be of more service, just ask.
Mike
Apr 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Black ink not printing
1. turn off the printer and open the front panel of printer
2. clean right side box wr all cartridge are stop
3. then change black cartridge
Mar 04, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
220 people viewed this question
old marine
old marine
