Question about ViewSonic VX924 19" LCD Monitor
Help in identifying this transistor for my VX924
Hey all,
I have a VX924 that would come on for about a second, then the screen would go blank. If I held a bright light to the screen, you could still make out the image oin the screen, so the backlights were turning off then shutting down.
I took it to my cousin who diagnosed that there were two Surface mount transistors (I believe transistors...hard to say without a schematic) that were shorting out. The are on the Invertor side of the PS for the lights, and are at position 'Q6' and 'Q7'.
Does anyone know what generic part numbers these transistors are? Anyone have a schematic?
Any help would be greatly appreciated!
PK
  • PK5150 Mar 18, 2008
    Thanks for responding waterppk!
    They are SMD pads, but with 3 on one side, and 1 on the other. The one on the one side seems to be common to the middle pin on the other side as per the circuit board...
    I checked out your link, because there is a two character code on it labeled 'QQ' and I believe I found the parts I need!
    npn RF fT 5.7GHz 2W hFE 40-80
    Thanks a ton!! You da Man!!
    PK
  • Anonymous Jan 20, 2009
    I got a Viewsonic VX910 that was black. Opened it up and there was a blown capacitor: c24 which is a 154j, 250mpp. I flipped the power supply over and two fried transistors: Q6 and Q7 which say "Dk QQ" on them.
    Scholar:
  • 42 Answers
Are they black with 3 SMD pads? They should have a tiny tiny number on the top corresponding to a SMD code that will tell you what they are (example: D9A means 5.5V zener diode).
http://www.tkb-4u.com/code/smdcode/indexsmdcode.php
You should be able to just get a new inverter or repurpose an inverter out of something else to get it working again. An inverter that powers any other CCFL bulb should work fine.
Posted on Mar 18, 2008
Screen goes blank after a second
More likely to be transistors.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Check the solder joints, fuse, transistors (c5706/5707), caps and look at other Dell albums also.
Replacement bd: www.lcdrepair.us
Apr 29, 2010 | Dell E153FP 15" LCD Monitor
My monitor(Samsung Model-540N,TFT) starts blinking.
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 09, 2010 | ViewSonic VX924 19" LCD Monitor
Viewsonic vx924 power/inverter board
See ebay item 390074135923
http://cgi.ebay.com/2-Inverter-transistor-viewsonic-VX910-VX924-DK-QB-QO-QA_W0QQitemZ390074135923
Fran
Jul 23, 2009 | ViewSonic VX924 19" LCD Monitor
ViewSonic VX924 transistor
Hey Brandon.
Besides those transistors, you may also fine the large capacitor adjacent to the transformer gone too, Possibly the transformer may be bad too ?
Also the 924s used at least two style boards.
Jun 17, 2008 | ViewSonic VX924 19" LCD Monitor
Viewsonic vx924 19" lcd
use a CRT monitor temporarily while you re-install the drivers for the monitor
Feb 27, 2008 | ViewSonic VX924 19" LCD Monitor
The monitor goes blank after just a few seconds or sometimes works for hours.
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supplyor other boards look domed or vented on the top.
Replace any capacitors accordingly. Monitor should work fine after that.
If not try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistora go bad. Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting the panel lights.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There's usually two light fixtures each of which holds two lamps. One fixture at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Feb 13, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Nov 30, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
My ViewConic Monitor has exactly the same problem as this another post? HELP!
Does it come back if you lower the resolution to the lowest and make sure the refresh rate is at 60 Hz?
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
658 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
