Question about Panasonic DMR-ES10 DVD Recorder
Stuck in self check mode
I have a Panasonic DMR-ES10 DVD Recorder, with a dvd stuck in it, it goes into "self check" mode, and I cannot eject the dvd.
  • 2 more comments
  • Anonymous Jun 16, 2008
    I'm having the same problem as described, but when I try to do as the suggestion offers, I cannot get the left side of the inner door to go down. Any further suggestions as to what to do?
  • Anonymous Jun 23, 2008
    I have the same problem ,
    i opened up the recorder, and found that the belt that drives the door open and close was broken .
    i need to find a replacement belt.
  • Anonymous Mar 23, 2014
    tv stays in stand by mode and won't eject the dvd how do i get it out
  • Anonymous Mar 24, 2014
    Stays in load mode and will do nothing else.
Hey, that worked and when I got inside I found the disc was out of line and blocking exit. Thanks
Posted on Aug 31, 2008
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
DVD stuck on Panasonic DMR ES10 in eternal cycle of "self check"/"please wait"
My DMR ES10 was eternally in a "self check"/"please wait" cycle. Couldn't even turn it off normally. By pressing the "Power off" for 10 seconds it will turn off forcefully. Now, after it says "BYE" press the "CH UP" (on the recorder, NOT on the remote))+"STOP" (with the recorder turned off) for another 10 seconds. This will force the opening and we now can take the DVD off. Turn the DVD recorder ON and, if the problem is on the laser, because of dirt, etc it will work and we can now run a DVD cleaner. In this case, the machine was stuck just because the first thing it does is check the DVD inside, and because it can't and just keep trying, it will never do anything else, until we take the DVD off with it turned off.
on Oct 18, 2013 | Panasonic DMR-ES10 DVD Recorder
Self check for over an hour
While the unit is switched off, Jim, press and hold the STOP and Channel Up buttons (BLACK SQUARE and CH/\) on the unit (NOT the remote) for 5-10 seconds and your disk should eject.
Apr 16, 2009 | Panasonic DMR-ES10 DVD Recorder
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
No user guide
hi....Download instruction manual of DMR-ES10 by clickiing this link It is PDF file and can be open / print through adobe reader . for adobe reader, go to
thank u
rate me
Feb 08, 2009 | Panasonic DMR-ES10 DVD Recorder
Dmr es10
I guess you must've hit a sequence on your remote to lock it up, try unplugging for a few hrs and turning it back on to see if it goes back to normal.
Oct 17, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic dmr-es10 firmware?
How do I check the firmware on a DMR-ES10
Oct 16, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
538 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
