Question about Canon EOS Rebel G 35mm SLR Camera
ERR CF Hi there - I have a Canon Rebel EOS. I just changed memory cards and now all I get is an ERR CF message whenever either of them are in the camera. We've used these cards before; they aren't new. Any idea why suddenly I'm getting an error?
  • akttol Mar 16, 2008
    That was it. There is one that I can clearly see is bent down. Thanks so much!
  • 667 Answers
The pins inside the camera may be damaged. Use a flashlight to check inside the slot where the card goes
Posted on Mar 16, 2008
SOURCE:
Error message ERR CF on my Canon EOS Rebel XT
hi, remove the card , peek inside the memory card slot , check if any of the pins are bent , there lies the problem , if everything is ok , then change the memory card or format the card , use a low capacity card, some card may be incompatible , hope this helps
Jun 06, 2016 | Canon Cameras
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon Rebel XT shows a CF Error , I changed the card and when I tried to format it shows error 99. THe Vattery is new and fully charged and right about the middle of the CF socket there are apparently...
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Thanks for choosing Fixya!
Jan 27, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Get Err CF in view finder and cannot take pictures
did you try removing the memory card and making sure its not locked?
Mar 18, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I get an Err CR inmy Canon EOS Rebet XT-Bad card?
  1. Test the CF card on your computer or another camera. If it works fine then it may not be the card. Make sure the card is not UDMA, 4GB or more in memory size since those new big cards are not compatible with the older cameras.
  2. Look inside the CF port. Make sure that none of the contacts that connect the camera and CF card are bend of smashed flat. If so then the camera will have to be send off for repair. This is a rather expensive repair, $250 is not uncommon.
  3. I it is neither of these then take the camera to a local camera shop and ask them to look at it. It may need to be sent off, but testing another brand card, or resetting the camera or checking for physical defects couldn't hurt at this point.
Nov 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I have a Canon Rebel XT EOS Every time i take a pic I get an Err 99. I have taken the battery out and memory card for 5 Min. If i do that I can take about 5 or 6 pics before I get that message again. What...
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err CF
I had the same message on my EOS/Rebel XTI and the camera shop concluded that one of the pins where the card is inserted into the camera had come loose. They sent the camera back to Canon for repair. Luckily, it was still under warranty at the time.
Chris
Jul 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Rebel XT will not work with new faster CF cards.
Check the volume and speed of memcard, maybe it is not compatible. error 99 is an indication that a lens or shutter curtain is not working, so i cant see any connection with the memcard problem. Check your camera memcard compatibility.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel G 35mm SLR Camera Logo
115 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
