Question about Funai FDRV90E DVD Recorder/VCR
Problem My dvd player shows p.scan and notthing comes up what should i do
    Sergeant:
  • 395 Answers
Return the setting back to 480i, your in progressive scan and your tv is not excepting the signal. your manual should tell you how. there may be a button on the remote or switch in the back of the unit or some sequence of commands to switch in to 480i. all DVD players are different in how this change is made. p.scan means progressive scan which is line doubling the picture standard tv's can not scan that high (EDTV's are 31.5KHz, standard tv's are 15.75KHz).
Posted on Mar 16, 2008
Dvd is stuck, won't play or do anything. Tried to unplug for an hour, still notthing/
does draw come out sounds like dvd not seated right and stuck in draw mech try pushing draw firmly
Mar 22, 2015 | Televison & Video
How do I get back to the Meue that I will show progressive scan mode. to remove progressive scan mode, because its stuck on the DVD, whereas we can't see the movie but we can hear the sound. I tried to...
1) Remove any DVD that may be inside
2) Press AND Hold Stop Button (on front of Player) for 5 or more seconds
3) All Done - This will have reset player back to Interlaced Mode and you can now see your DVD!
Feb 15, 2011 | Zenith XBV343 DVD Player/VCR
Lh-d6245 dvd player in progressive scan mode no picture
put a dvd into player and let it play, than press stop, sysem show stop, than press stop again for 5 sec, and the LG screen will be back to tv screen.
Jun 28, 2008 | Progressive DVHE210 210 DVD Player
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 25, 2008 | Memorex Progressive Scan DVD Player...
Dvd(rca)
check all your connections and make sure the video out of the dvd player is going to the video in on the tv.also if it is a progressive scan dvd player, try pressing the progressive scan button.
hope this helps.
wg
Feb 12, 2008 | RCA DRC255N DVD Player
Need device code
i have a cyberhome dvd ch 300 and the screen has blanked out but the voice is coming through clearly. It is not showing from the usual video output but it shows very wavy on the other progressive scan lines what can i do
Jan 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd player
It could be that the DVD player is set to an improper scan setting (Interlaced/Progressive)
If the TV does not do Progressive scan it can sometime sshow up as jumpy, or not show a picture at all. See if there is any mention in your manual about this setting and change it back and forth just to eliminate this as an issue.
Nov 22, 2007 | Televison & Video
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Funai FDRV90E DVD Recorder/VCR Logo
66 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
