Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Haywire dishwasher contol panel
Fisher & paykel dish drawer
the control panel is going crazy - it plays the star spangled banner and will not stop scrolling through symbols and numbers...i have to reset it and clear it somehow...
  • 1 more comment
  • Anonymous Mar 16, 2008
    刷新版本
  • cjb10 Mar 17, 2008
    Thanks unplugging worked! I thought of it myself though....
    Yes, I saluted! It also plays Bach's Jesu, Joy of Man's Desiring, the song you hear at wedding ceremonies...it made the experience just lovely!!
    Thanks again!
  • ComputerMike Apr 11, 2008
    How do you unlock the lock of the draw on the DD603ss
I had the same problem. Played Fur Elise and the Star Spangled Banner when you press and hold the middle button. Before that it was not draining and the lights were blinking blue and red.
I found the breaker to the power for the dishdrawer, turned it off, then back on. That seems to have worked. We are not thrilled with the number of times we have had to call for service or run an extra rinse cycle because the top drawer did not drain all the way. We got a full rebate for the cost of the unit when we bought a DCS range and hood so it was free. Not sure I would buy on though.
Good luck.
Posted on Nov 10, 2008
    President:
  • Fisher and P... Master
  • 2,651 Answers
Did you stand up and salute it properly!!!. just kidding , were you using the d/w when this happened??? either under te sink or sometimes if you pull out the lower drawer youl be able to unplug the unit perhaps had an electrical glitch...if you can pull out lower drawer theres a pretty good trouble shootertaped inside the back wall
Posted on Mar 16, 2008
Fisher & Paykel dishdrawers - no power at all to the top drawer
Try and do a power reset to the dishwasher. This means turn the mains power off to the dishwasher and back on again. If there is no mains socket under the kitchen bench then maybe do this from the mains contactor switch in the meter box. If there is no difference to the behaviour of the top drawer then the controller has most likely packed up. You can test things out by taking controller from bottom drawer and putting in top drawer. But this requires some experience with taking out the front covers of the drawers, taking out the connectors and putting back. If you mix the connector connections etc you can cause more damage. Take photos as you go along. Make sure the dishwasher is disconnected from mains power when you are working on it.
Feb 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Was awakened in the middle of the night by the F&P dish drawers (top drawer) playing the "Star-Spangled Banner" alternately with "Brahms Lulliby", lights flashing, lots of beeping! .....the lights...
Not funny Cindy - Any chance you can access the power breaker in the panel for the dishwasher? Sometimes with even short power bumps or outages, electronic controls get out of whack - Leave the breaker off for a minute and then turn it back on - As for the water level, I would question if the hookup was done entirely correctly - The idea is for the drain to connect to the most clear point of the sink drain - if you drain came with a pre-made Dishwasher drain connection, did the installer make sure that the plug was fully removed before connecting - Even in my mobile dishwasher I might get an inch of water, but not what you are experiencing - Good Luck
Feb 09, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
I have a F&P DD603I with NO lcd, just lights on top at the wash control panel. The HEAVY, FAST, and RINSE lights are all on at the same time. At one point the thing was playing the national anthem...
HI- I think your controller is faulty. I've only encountered the Star Spangled Banner issue once and replacing the controller fixed the issues. You may try to unplug the power cord for a few minutes and plug it back in and see if it resets but I don't think that will resolve it. I'd give Fisher/Paykel a call and see if they can narrow it down for you, they are often helpful.
Oct 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
469 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
