Question about Kitchen Ranges
My oven a number came up F2- what does this mean
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
F2 is a faulty oven temp sensor. need to replace the sensor. located in the oven cavity 2 screws hoding in protrudes 3-5 inches out thin metal cylinder
Posted on Mar 16, 2008
One controller keeps flashing F2, what does this mean. It will not go to any setting on/off , raise or lower heat setting, etc.
All the information is here. It is a heating sensor error. There is also a video.
If you have a GE oven with an electric ERC, F2 means it is over heating. It is an oven. It is supposed to heat up. For the GE electric ovens and some others, F2 means it thinks the temperature is 590 degrees or higher with the door unlocked or 990 degrees with the door locked.Oct 11, 2015
F2 Google Search
Dec 10, 2016 | Ovens
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
What does eroor E6 Mean
The E6-F2 error code indicates a problem with the touchpad or the electronic oven control. E6-F2 specifically means the cancel key drive line is open. You can't cancel this error code, but sometimes removing the power from the oven and reconnecting it will cure it.This is usually a fault in the touchpad, but can also be caused by the electronic oven control. To test the oven you would need to remove the control panel and disconnect the ribbon connector from the touchpad to the oven control at the oven control. Clean the end of the ribbon and reconnect it. This will sometimes correct the problem by curing a weak connection. If the error code comes back you should replace the control panel which contains the touchpad. 8300427- black
8300428- white
8300516- biscuit
The part number for the electronic oven control is 8302319.
Apr 29, 2014 | Heating & Cooling
Whirlpool oven shuts off - Error Code F2
The "F2" error code for this oven means "one or more keys on the keypad are shorted". The correction is to replace the control panel because keypad does not come separate.
The part is not available but if you call the number of that supplier I'm sure they may find the part for you.
Here is the info.
Nov 09, 2012 | Kitchen Ranges
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
F2 code on my whirlpool stove buttons not working.
The F2 could mean a timer/control has detected a stuck/shorted keypad. Depending on the model number though it could also mean a shorted oven temperature sensor.
In the event it is a stuck keypad detected, the timer or keypad will need to be replaced. You should first attempt to reset the breaker or unplug the range for a couple of minutes to see if that resolves the error code.
If it is the model that uses F2 as the shorted sensor code, you`ll need to replace the oven sensor, there`s no way around that one.
If you can provide a model number by replying to this post I could try and be more specific, as right now I can only generalize with the most common F2 error codes meaning for Whirlpool manufactured ranges/ovens.
Hope that help`s, let me know.
Good luck.
macmarkus :)
Dec 06, 2009 | Whirlpool 30" Freestanding Gas Range -...
Display screen says E3 F2. What does this mean?
The F2 on whirlpool ranges means the oven temperature sensor is defective, you`ll need to replace it.
**Disconnect any power to the unit before attempting any self service please**
The part number is 8053344 and retail's for approx. $30-$40US.
It should look like this just so you know, and with an ohm meter should measure approx. 1100ohms at room temp.2677baf.jpg Hope that helps, let me know please. Good luck.
macmarkus :)
Nov 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven Flashing "F2"
hi thanks for the question. F2 means a high temp, and to look at the oven sensor circuit.I would replace the sensor. not too expensive and try . the other solution is the circuit board. so try the sensor. thanks the appliance doc
Sep 29, 2008 | GE Profile JTP18 Electric Single Oven
Oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Apr 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Nov 22, 2006 | Kenmore 62622 Microwave Oven
Kitchen Ranges Logo
123 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
