Vizio on the fritz
Hi all, I have a vizio p50, last night was watching ok then heard something pop inside tv, image got dim
and menus and on screen display got very slow.
Now it wont even turn on, could the power supply cause this? this tv would every now and then have a constantly clicking relay and not turn on. Any input would be apreciated
  • 1 more comment
  • Anonymous Mar 16, 2008
    p50hdm plasma
  • Anonymous Apr 07, 2008
    thanks bobbyj!! replaced the board and everything is back to normal.
    I checked visually all components & with ohmmeter checked all diodes on the board and found nothing wrong, so I'm assuming that one of the IC"S under the heat sinks is fried, surely because of over heat. So I added a small power supply fan on top in between both heat sinks and wired it to the stock fans, to help in the cooling, will add one to the ysus in the future. Lets see if this solves the 18 month brake down hump on these units.
    Thanks again
    AJ
  • Robert Johnson May 11, 2010
    what is the full model number? is this a plasma tv?
    Sergeant:
  • 395 Answers
Replace the Z sustain board part # 6871QZH044C.
Posted on Mar 16, 2008
SOURCE:
I have an LG 42" plasma tv (model: 42pc1da) and I am having a major picture problem with it. Last night, while watching the television, I heard an audible "pop" and the picture started to dim. I turned the...
The sound you heard came from one of the IC's under the heat sinks. Check the fuses on the left and right print, the print with the broken fuse must be replaced.
Sep 03, 2010 | Televison & Video
I have a vizio p50 hdm tv and i heard the pop of death and have a faint no signal display in the middle of the screen. can you tell me what happened?
something is wrong with your z board
you need to open the back of the tv and check the fuses on the boards it has 3 boards
left side y board ,right side z board .
check the fuses first
thanks
www.itvrepair.com
May 19, 2010 | Televison & Video
I have a Vizio P50 HDM and while watching it last evening I heard a loud pop and the picture went into a very noisy/distorted condition. Sound is OK. Any ideas?
That loud pop is your Y and Z sustainer. Normally it goes out completly but yours is still half working. Not usally fixable yourself, because you may need to flash the control board f/w , which is proprietary and can't be aquired unless you work for them,
Jul 08, 2009 | V, Inc. Vizio P50HD Plasma Television
HELP PLEASE Vizio Plasma tv broken again - possible driver board?
This could cause by the power supply or the mainboard.
- If the LED stay Green when you turn on the TV. But you can not turn it off, in this case the main board has failed. Replace the mainboard will fix the problem.
- If the LED light always stay at Orange, you can not turn on of off. In this case the mainboard also has failed.
- If you turn on the TV you will hear the power supply click on the LED is green then it click off the light turn Orange. In this case the power supply has failed.
Which boards did the repair shop replace?
Hope this will help.
Feb 18, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Big POP no sound no picture
if you could see light orange or green is has power is probably teh Y and Z board
Aug 22, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Heard popping now want turn on
Hi there!
Something did pop. Could be the fuse or something else. My guess as good as yours. Good luck, JUS004
Feb 26, 2008 | GE 25GT538 25" TV
Vizio P50 screen refresh
power supply.Definately will need to be replaced. Im actually looking for one to replace myself.TV repairs charge 1200 to repair.
Nov 01, 2007 | Vizio P50HDTV10A 50 in. Plasma HDTV
P42W46X
take visa or mastercard to local best buy for new tv. sorry
May 26, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
Ekse
