Question about iRiver iFP-795 MP3 Player
Mp3 player my mp3 device when n connect it to my pc device show usb connected but pc dose't show in
  • Anonymous May 23, 2008
    when put the usb in the computer shows it but it telling me about installing cd
    Master:
  • 351 Answers
Dear Bhuwan,
you can download the music manager software for your IFP-795 ,from this site:
http://www.iriveramerica.com/support/ultra/iFP-manager-pc.aspx
for download this software you have to just click on iriver Manager 3.16
Regards
Posted on Apr 26, 2008
Hi. i am tryinmg to charge my nieces mp3 that she has got. she lost the original chatger (lead) so i am using a spare one that i have found.. its coming up on the screen connected but its not showing the...
Hi, why it's not charging yet ,i think its not yet recognizing the mp3 player yet. You will need to follow the below step and solve the problem.,Then after trying out this steps and still does not work,That means you will need to replace the USB cable...
Hi, when an m3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Good luck......
Mar 12, 2011 | Audio Players & Recorders
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
Refresh the drivers
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Brand new gogear keeps freezing up when I connected to computer
Do you allready try in other computers?
Turn off your antivirus, and try to connect
its your computer usb 2.0 (when u connect mp3 player to your pc show something like This device works better in a 2.0 usb port?)
Some times a non original version of Xp dont really works good whit usb devices as digital cameras, usb flash memories, cell phones, and all in one printers (extraible disk drives); In This case try first in other machine if this works reformat your machine o if you got the restauration cds used in your pc
Oct 17, 2009 | Philips GOGEAR SA6045 MP3 Player
Download onto mp3 player
You may first want to check to see if your player came with software that can aid in this process. You'll also need to know what formats of media your player accepts. For these purposes, we'll assume your player accepts mp3 format media and connects to your PC via USB.
1. Connect the device to a USB connection on your computer.
2. If you're using Windows, your computer should automatically detect the device, probably showing it as a removable hard disk.
3. Double-click the removable USB device that your computer now sees and here you will have to browse to see where your player will accept the media; likely, right here will work.
4. Now, just copy & paste mp3 files from your pc to your media player/removable USB device.
5. When done, safely remove the player from the computer.
Jan 03, 2009 | Microsoft Windows Media Player
Mp3 player not working
mp3 player is showing a flash error message.Please back up the data and format the player.
Aug 29, 2008 | iLO (2 GB) MP3 Player
Infitek mp3
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 31, 2008 | iLO (2 GB) MP3 Player
My computer don't found my mp3
The HDD1630 is only compatible with Windows XP and Windows Media Player 10.
If you have Windows Media Player 11, unistall it to roll back to version 10.
Install and run the Philips Device Manager from the product CD.
Connect the HDD1630 to the power supply and connect to the PC.
The MP3 player should show as an MTP device. There should be a connection icon on the player screen.
Start Windows Media Player, and select the SYNC option to transfer music.
Feb 17, 2008 | Philips HDD1630 MP3 Player
My sony VGN N220E does not detect external devices
Try reinstalling your usb ports.
1. goto desktop, right click on my computer and press manage.
2. goto the device manager, find the usb devices / ports.
3. Make sure you are useing a ps2 mouse / keyboard since if your mouse/keyboard is connected to usb they will stop working untill your pc is restarted and the devices are reinstalled.
4. Uninstall all usb devices.
5. after all usb devices are uninstalled reboot the pc.
If the problem is with your drivers ( your pc detects the mp3 player but no drivers found) Download the newest drivers for your product and operateing system from the vendors website.
Nov 30, 2007 | Computers & Internet
Not recognized by the computer
my mp3 says not enough DM space and it wont show up on the computer
Nov 30, 2006 | SanDisk Sansa m230 MP3 Player
iRiver iFP-795 MP3 Player Logo
167 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
