Help with fm presets
I have a Sherwood R965 and want to program the preset FM stations and cannot find in the manual how to save each preset. How is this done or what page is it discribed?
Thanks John
    Scholar:
  • 105 Answers
I'm not sure on this particular model, but often if there are seperate buttons for the station presets you just tune to the required station and hold the preset button you want in until you hear a beep - then the station is memorized in that preset.
However in this case the preset up/down and enter/memory buttons are used - the manual is available here:
http://www.sherwoodusa.com/cc_manuals.html
and full instructions for setting presets both automatically and manually are on pages 35/36.
Posted on Mar 16, 2008
SOURCE:
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Programming FM tuner preset buttons
scan for the station when you have the station hold the number button you would like the station to be on in until it flashes when flashing leave and push memory or dont push memory and wait until it stops.
Dec 28, 2013 | Audio Players & Recorders
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
Instructions on programming Nakamichi SS5 radio presets
The solution is really very simple.
This unit is capable of a total of 30 presets.
10 AM presets in 2 groups (AM1 & AM2).
20 FM presets in 4 groups (FM1 - FM4).
Each of the individual groups can have a total of 5 presets.
In other words, there are 6 groups of 5 presets (AM1 AM2 FM1 FM2 FM3 FM4) for a total of 30 presets. Hope that makes sense.
You have preset buttons 1-3 on the top of the unit. Preset button #3 is the MEMORY or "set" button.
Try these steps and you should be up and running.
1. Choose which band you want to use. ie. AM1 AM2 FM1 FM2 FM3 FM4.
2. Tune in a station
3. Click the #1 preset button and watch the screen, let's say that you have tuned into the station FM 100.0, the station frequency is displayed along with the "group" you're in (ie. AM1...FM4) and you will also notice a number in between your "group" id and your station. This is the # you're going to set and the way to change this from 1-5 is simply by pressing the #1 preset button until the # comes up that you want to save it to.
4. Press #3 Preset button (labeled "MEMORY")
5. That's it, now do all the stations you want but be mindful that once you have programmed 5 presets to any given group, you have to move on to the next group until you've maxed out the total # of presets.
Hope this helps.
Jan 25, 2009 | Nakamichi SoundSpace 5 Shelf System
2003 Lexus ES300 How does one save Radio Statio presets? Going to the station and holding the button to save does not work.
Holding the button is supposed to work. This from owner's manual: PRESETTING A STATION:
  1. Tune in the desired station.
  2. Push one of the station selector buttons (1-6) and hold it until a beep is heard. This sets the station to the button and the button number (1-6) appears on the display.
Each button can store one AM station and two FM stations. To change the preset station to a different one, follow the same procedure. The preset station memory is cancelled when the power source is interrupted by battery disconnection or a blown fuse.
Jan 08, 2009 | 2003 Lexus ES 300
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
RX-397 FM Station presets, both in Auto or Manual, DIFFICULT to control.
I took a deep breath and realized that I had to push memory twice. Once to engage and once to set.
Apr 27, 2008 | Yamaha RX-397 Receiver
377 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
