Question about Canon Selphy CP510 Thermal Photo Printer
Can't print on Canon Selphy CP400
Having problem with paper feeding into the printer. The 4x6 inch cassette fits properly, but no paper is fed after clicking "print". The printer reacts to the common, but not the paper (with 3 or even 15 sheets in the cassette). A red light came out inidcating that there is a problem.
  • bhay08 Jun 06, 2008
    I have a Canon Selphy 510 and am trying to print via my computer. it simply will not work.
  • 127 Answers
SOURCE: Color ink cassette stuck in canon selphy
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Posted on Jul 10, 2009
dnewcombe1
  • 1564 Answers
SOURCE: My HP LaserJet 3050 will not grab and feed paper
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
Posted on Sep 04, 2009
  • 13 Answers
SOURCE: My Samsung CLP300 has a paper feed problem. When
Lift up the front of your machine about 4 inches with a book.
The paper will now feed easier.
Richard
Posted on Oct 29, 2009
SOURCE: cassette has paper in it; fresh ink cartridge; can
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Dec 21, 2009
Testimonial: "That was exactly the information I needed. It still needs a little push on the paper once in a while, but I'm back to printing. THX"
SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7...
paper size is incorect
Posted on Oct 12, 2010
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Paper size
It looks likes the unit comes with a Paper Cassette PCP-CP400 which is for Postcard Size paper. You should be able to reuse the Cassette for any postcard size paper. If you want to use L Size or Card Size paper you will likely need to purchase an additional cassette for that size.
Jan 01, 2013 | Office Equipment & Supplies
I had to completely unscrew and disassemble the printer then cut or break the piece of plastic from the removable ink cassette that was blocking it from being removed. See attached pic.1_3_2013_5_05_41_pm.jpg
May 18, 2010 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Cassette has paper in it; fresh ink cartridge; can hear the engine running, but I get a paper feed error Canon Selphy CP510
Dec 21, 2009 | Canon Selphy CP510 Thermal Photo Printer
Paper stuck in the printer because of dead camera battery
Been there before. There is no easy way to do this however you can call canon and there is a reset switch pattern that will rest the memory in the machine and run a self test at start up this may help
Nov 06, 2009 | Canon Selphy CP400 Thermal Photo Printer
What is the correct way to load the paper.i cant get it to feed
On the Selphy printers you put the paper on the front tray just up to the rollers. When you print the paper is drawn in toward the rear, and then prints on the way back out to the front tray.
Aug 19, 2009 | Canon Selphy CP400 Thermal Photo Printer
How do I load the paper in the canon selphy cp400 printer. This was given to me with out the operating manual.
You can download the User Guide (in PDF format) here
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=359&modelid=11047
Just scroll down to the Guides & Manuals Section and download the file Named :
Compact Photo Printer SELPHY CP400 User Guide
CP400UG-EN.pdf
Nov 30, 2008 | Office Equipment & Supplies
Printing onto photo paper from mac g4 computer
I put the 4x6 in the bottom cassette. I place it with the shiny side down. Landscape is when the 6" length is front to back in the tray.
I use the cassette exclusively for 4x6 and use the back tray for all else. It works great.
Apr 20, 2008 | Canon MP610 Photo All-In-One Printer
Canon Selphy CP510 Thermal Photo Printer Logo
349 people viewed this question
old marine
old marine
