Question about Sony Network Walkman NW-E005 MP3 Player
Database deleted Hi When I cleared all the files off my walkman it said there was 500mb available, thoug it is a 1gb model. So I formatted it, thinking this would clear it. Now it says NO DATABASE AVAILABLE. Can anything be done about this?
  • reidb101 Mar 25, 2008
    DOES ANY ONE ACTUALLY KNOW HOW TO FIX THIS PROBLEM IT SAYS NO DATA FOR SOM STRANGE REASON IM LOST I DONT KNOW WAT TO DO CAN ANY ONE HELP ME (REIDB101@HOTMAIL.COM)
    NO DATA BASE WAT THE HELL I HAVE MUSIK ON IT THOUGH ? ANT SUGGESTIONS
  • 242 Answers
The player doesn't accept removing of music, or formatting, when it is not done from SonicStage, the software that sony offers with it.
The software is to be downloaded here. When you've installed the software, format the player from the menu. Then transfer your music with this program.
That'll do the trick.
Please rate the solution if it helped
Posted on Mar 31, 2008
I deleted files off sony walkman mp3 and now it says no database but when i plug it in to somethin it plays
Connect to a PC and format the drive. Now select and transfer the accepted media files - converted- to the player. It must play on if not reset the player.
Oct 01, 2011 | Sony NW-E002BC Walkman MP3 Player
Dropped two days ago, seemed fine. all of a sudden started freaking out. screen looks like TV static, then freezes on start up screen.
I suggest you to backup all the songs in the Walkman Player to the Computer and Format the Player.
Connect the Player to the Computer to charge it until FULL message is displayed.
Reset the Walkman Player. To reset it by pressing the RESET button with a small pin or similar object. You can also Format the Player if the Format option is available by accessing the Home Menu.
To Format the Player; press and hold the BACK/HOME button, select Settings-->Common Settings-->Format-->YES.
WARNING: There is a risk of data loss. If the memory is formatted, all files including the Operation Guide (If applicable to your model) stored in the player will be deleted. Be sure to verify the files stored in memory prior to formatting and export necessary files to the hard disk of your computer or other device.
Once the Format completes, reset the Player by pressing the Reset button located at the bottom of the Player using a sharp pointed object. Now you can transfer the required songs and files to the Player using the supplied Software or by dragging and dropping the songs through Windows Explorer. This will resolve the issue.
Good Luck!
May 05, 2011 | Sony Walkman NWZ-S616F MP3 Player
Hi,could any one please help me i've lost my DATABASE of walkman NW-S203F someone told me that my walkman NW-S203F will never work without the DATABASE now the walkman NW-S203F is empty and it does not...
You need to install Sonic Stage software in computer that can be downloaded from Sony Support site as per OS running in PC then connect walkman with computer and transfer mp3 files in it, Sonic Stage will create that database files automatically to solve the issue. Download related info as well.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony Sports Walkman NW-S203F MP3 Player
I delete things but available space doesn't increase
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Oct 01, 2009 | Memorex 32573060 Rotodrive 3pk - 1gb Media
No Database
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
Sep 18, 2009 | Sony Network Walkman NW-E005 MP3 Player
NWZ-B135 Database Restoring
To upgrade the firmware,you need to download the firmware from here: http://support.sony-europe.com/dna/downloads/firmware/firmware.aspx?site=odw_en_GB&m=NWZ-B135&f=FRM_NWZ_B13x_f after downloading,run it and then connect the player to system while holding the "volume -" button...it should be detected and the firmware would be restored.
Aug 25, 2009 | Sony Walkman NWZ-B135 MP3 Player
Can't Delete Files From Global MP3 Player with Mac OSX
When moving an item to the trash, it actually is just in a hidden ".Trash" folder on that disk, so no space is actually freed up. Can you try hooking the drive back up and then emptying the trash?
Jan 18, 2009 | Global Marketing Partners V3-8B512G (512...
No database on my sony mp3
YOU HAVE TO DOWNLOAD FIRST THE INCLUDED CD SOFTWARE BEFORE YOU DOWNLOAD MUSIC.
Sep 11, 2008 | Sony Network Walkman NW-E005 MP3 Player
Database full ns-2v17b
Your database is corrupt
You have two choices here:
1) Delete the songs
2) Reformat the player
The player isn't trying to BS you
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 11, 2008 | Insignia NS-DV2G MP3 Player
No database.
Download SonicStage software here. When you've installed the software, format the player from the menu. Then transfer your music with this program.
That should work.
Mar 29, 2008 | Sony Network Walkman NW-E005 MP3 Player
Sony Network Walkman NW-E005 MP3 Player Logo
103 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
