Question about Linksys Wireless-G WUSB54GS 802.11g/b
Setting a new static IP in router
My ISP changed my static IP and said I should do the same in my router. 192.168.1.245 does not open access point log in. How can open the page to modify the static IPs in my router?
    Scholar:
  • 178 Answers
On a linksys router, the "DEFAULT" IP setting is 192.168.1.1. If you can't access it through that IP, you'll need to do a hard reset to be able to configure the router once more with the suggested change from your provider. To do a hard reset, locate the reset button on the back of the router and hold it in with a paper clip for 30 seconds. Unplug the power from the router, wait a moment and plug it back in. When you access the router with the factory settings, you'll leave the username blank and the password will be admin. Enjoy.
Posted on Mar 16, 2008
SOURCE:
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Remote Access
IF you are getting public ip from your isp, please go to administrator tab of the router and first change the router's password which is on the top on same page in black dots,,type your new password by deleting old one and re-confirm it just below and save it..router will prompt for the new password just to let you know settings are saved now enable remote managment option on the same page and port is 8080(default, you can use your own port number) and save setting..now you are ready to access your router remotely for that note down the public ip you are getting on your router's status page and in remote location you need to type something like :- http://x.x.x.x:8080...x.x.x.x is your internet ip (public) and 8080 is port number for remote management.
For host applications need to know which application you are running according to that need to open port in the router using Port Forwarding feature of the router.
Jul 15, 2010 | Linksys Wireless-N WRT150N Router
My asus wl-500gP v2 can't connect to the wan properly... I get the message "you have set the wrong dynamic or stic IP address for you WL-500gP V2." I'm confused because I have it set to dynamic which...
Your ISP address is dynamic, which means every time you log on to your ISP, your WAN IP address changes, this helps to stop hacking. Your ISP even though it is cable uses PPPoE/PPPoA, so you should set your router to this, not dymamic, setting your router to dynamic will make your router look for a different IP address every time your computer tries to log to it, your computer should have e.g 192.168.1.2, which is static, you can check this by going to command prompt and typing ipconfig, see what it brings up. hope this helps and post back if you need further help.
Apr 03, 2010 | ASUS WL-500gP V2 Router
I can't install a Netgear wgr614vp router - stops in the middle and says, "we have detected a static IP address" - won't let me go any farther
The fact remains, unless Comcast (your ISP) has given you a "static" IP odds are that your IP is in fact NOT static, but dynamic (where your ISP can change your IP at the drop of a hat. I am wondering what the router is detecting to tell it that your IP is in fact static? Comcast OUGHT TO be able to tell you, without getting one of "their" routers, if your IP is static or dynamic. Comcast has this answer, and no onev else, so keep after them.
At any rate, you ought to be able to get to your router control by pointing your browser at http://192.168.1.1 and log in with the following:
User Name: admin
Password: {leave this blank}
Once you've logged in let me know and we'll take small steps to get you online, OK?
Jan 17, 2010 | NetGear WGR614 Wireless Router
Need basic step-by-step instructions on how to install my router.
  3. Reboot the PC.
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Linksis router wont work help me out
First of all contact your isp and get your connection settings. If you are able to setup the router using the cd provided then good. If you are still having problems then go ahead and contact linksys (remember linksys charges for the support). I suggest get a technician to assist you in setting up.
Jul 22, 2009 | Linksys Wireless-G WRT54G Router
I have a static ip that wont access the WAN through router.
I want to make sure that you aren't confusing the routers DHCP setting for your ISP, versus, setting the router as DHCP so that your clients can receive an address inside your wireless router. If you go to this page, you can find the routers user guide manual, you'll only need to make sure you input the correct version for your router either version 1 or version 2.
http://www.linksysbycisco.com/US/en/support/WRT55AG/download
On page 21 of the pdf manual. You'll find information on setting the DHCP server settings. Here you can assign a static IP to your clientl. The only thing you'll need from that device is the MAC address.
Best of Luck.
Apr 22, 2009 | Linksys WRT55AG Router
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
Linksys Wireless-G WUSB54GS 802.11g/b Logo
62 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
