HP OfficeJet 6210 All-In-One InkJet Printer Logo
Posted on Apr 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A message keeps saying print cartridge access door
A message comes up sayingthat the print cartridge access door is opened but everything is closed. What is happening. Also it tells me print cartridge jam. I am not able to print. Please help.
Anonymous
Level 3:
  • Master 666 Answers
  • Posted on Apr 04, 2010
Anonymous
Master
Level 3:
Answers
666
Questions
0
Helped
204833
Points
1944
Check that sensor function while open / close upper cover, some time hook type sensor connector broken and need replacement. check also roller for possible stock paper.
Cartridge door open message won't go away
see door switch your door switch have problem
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
2answers
It keeps on sayin my access door is open but my printer doesnt have a rear door
Access door is usually the one that opens to allow the insertion of new cartridges. Try opening and closing that one and restarting the device after completely unplugging from the mains and waiting 30 secs.
Please rate this answer!!
Cheers
Bob
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Check print cartridge blinking cartridges refilled today and installed laptop not recognising printer as result
    • If the message on the computer does not identify a particular cartridge (it says only Print cartridge error ), follow the steps below to determine which cartridge is causing the problem.
        • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed), then the cartridge you have removed is the problem cartridge.
  • If the problem still occurs, the electrical contact between the cartridges and the printer might be bad. Removing and reseating the cartridges might help. Also, you can clean the electric contacts on the cartridges with a dry cloth.
Hope that will help solve your problem!
1helpful
3answers
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Hp 1410 all in one keeps saying prin cartridge error
Follow the steps given below and check for the results
=== Cleaning the ink Cartridges ===
Even if the cartridge is new, follow the steps below to clean the print cartridge contacts. Print cartridges have a substance on the contacts to keep them from corroding during storage that may cause poor electrical contact between the print carriage and the print cartridge.
  1. Verify that the product is turned on. NOTE: If the HP product is not turned on, you will not be able to remove the print cartridges.
  2. Open the unit to access the print cartridges.
  3. After the print carriage (the part that holds the print cartridges) stops moving, unplug the power cord without turning off the unit using the power button. If you turn the unit off the print cartridges will be capped to prevent them from drying out and you will not be able to remove them. You must unplug the power cord to prevent the print carriage from moving.
  4. Remove both print cartridges.
  5. Verify that the part number on the cartridge is the correct part number for the unit.
  6. Using a cotton swab or lint free cloth (like a coffee filter) lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the cartridge. Figure 1: Electrical contacts c00055424.jpg NOTE: When an all-in-one is used frequently for black and white printing but infrequently for color printing (for example, an all-in-one that is used primarily as a fax machine), the color cartridge will still eventually fail and need to be replaced. The pins in the print carriage can cause dents on the contact points of the color cartridge over time (usually between six and twelve months).
  7. Wipe the contacts with a dry, cotton cloth, as shown, to dry the contacts and finish cleaning. Figure 2: Wiping the contacts c00055425.jpg
  8. Reinsert the cartridges and lock them in place.
  9. Close the top cover or access door and plug in the power cord.
  10. If the error continues, repeat these steps. If further cleaning fails to clear the error, proceed to "Step two: Cleaning the print carriage contacts" below.
Step two: Cleaning the print carriage contacts Have the following materials available to clean the print carriage contacts:
  • Cotton swabs or any soft material that will not come apart or leave fibers.
  • Distilled, filtered, or bottled water (tap water may contain contaminants that can damage the print cartridges) CAUTION: Be careful not to get ink on hands or clothing.
Do the follow to clean the cartridge contacts inside the product:
  1. If the unit is off, turn it on.
  3. After the print carriage stops moving, unplug the power cord. Do not turn the unit off before unplugging the power cord.
  5. Using a cotton swab or cloth lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the print carriage as shown below. Figure 3: Cleaning the carriage contacts (your model may look slightly different) c00130268.jpg
  6. On models equipped with locking latches, lower the latches. Figure 4: Latches in the lowered position (your model may look slightly different) c00055427.jpg
  7. Wait five minutes for the contacts to dry and then plug in the power cord. The unit will begin to reinitialize. Wait until the process is complete before proceeding.
  8. Reinsert the print cartridges when prompted and then close the top cover or access door.
  9. If the message recurs, replace the print cartridge indicated by the message. If you are using refilled or remanufactured cartridges or non-HP cartridges, replace them with new HP cartridges. HP cannot guarantee that refilled or non-HP cartridges will function correctly in HP products. If a new HP ink cartridge is defective, return it to the place of purchase with the receipt, or contact HP to obtain a replacement.
  10. If the problem still exists, replace both print cartridges. Since the cartridges are electronically connected through the printed circuit board, the cartridge not indicated in the message might be the causing the failure
If the issue still persists then try the following steps to identify the problem ink cartridge
1. Remove both the ink cartridges
2. Insert the Color ink cartridge first and close the ink access door
3. Check if you are getting any error message or the ink cartridge light is blinking
4. Now remove the color ink cartridge and then insert the black ink cartridge and close the ink access door
5. Check if you are getting any error message or the ink cartridge light is blinking
Replace the problem ink cartridge anc then check
My printer dont want to print
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
3helpful
2answers
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
2answers
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
k24674
Grand Canyon Tech
Grand Canyon Tech
