Oven preset to 400 degrees won't heat beyond 200 degrees. Broiler seems to work ok. Any solution?
Any idea where to get parts numbers for this model? Maytag's website seems pretty useless. The model number does not even come up. BTW it should be 5750 in the title, not 57550
Can you see lower (bake) element or is it hidden(under the oven floor). a visual inspection of elemnet is usually all that is required to determine if its good or not, It will have a "burn out" in it perhaps a plume of white soot around damaged area.in which case you will need to replace the element. simple enough 2screws and 2 wires part number 74010750.. if it is a "hidden" bake elemnt the floor oh oven lifts rightup to reveal it."POWER MUST BE TURNED OFF!!!!!!!! IT IS A CONSTSANTLY LIVE ELEMENT!!!!!!!!!!!!
forgive me hfor the duplicate question here, There are 2 elements in this oven ( in all ovens for that matter),i understand the broil element is working.there is also a bake element .not quite sure we were on the same page there. the lower(bake) element is good???if you dont see one on the floor of the oven, hten the bottom floor will lift up to reveal the element. If both theses elemnts ck good a quick loook from behind for burnt wires and id say you have a bad electronic control.
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
only one visable element on top. broiler function works fine.. possible digital preset panel malfunction or maybe digital thermometer is my guess. I wish it was as simple as a burned out heating element.
I have the same problem with the same unit. Have you found any answers? I do know it is not the heating element. My next step is the thermo. I'm worried it is a computer problem.
